FWTools 1.3.6 using mapserver 5.0.0-beta4
Milo van der Linden
mlinden at ZEELANDNET.NL
Wed Sep 12 12:11:44 EDT 2007
I figured it out. The trick is to take all the contents of the
ms4w/apache/cgi-bin/ directory and OVERWRITE everything in
C:\Fwtools\bin...
Now php_mapscript.dll works like a charm under IIS, without all the extra
load that ms4w brings!
> Hello list!
> I am in the proces of installing mapserver on IIS 5 with php and
> php_mapscript.dll keeps crashing.
> I used FWTools 1.3.6 and been cracking my head why it would not work.
> Now I discovered that a mapserv.exe -v command shows version 5.0.0-beta4!
> I decided to uninstall FWtools 1.3.6 and revert to 1.3.4
> Now I have mapserv 4.99. When I php from the command prompt, I get the
> error:
> "cannot find entrypoint for procedure msDrawQueryMap in dll-file
> libmap.dll"
> any suggestions? Do I need to revert further back to get the
> php_mapscript.dll working? I use the one that comes with ms4w.
> What I did:
> - Installed fwtools
> - copied only the php_mapscript.dll from the ms4w package into c:\PHP\ext
> - added extension=phpmapscript.dll to my php.ini
> - made sure the paths point to C:\PHP and C:\FWTools\bin and so on.
> Is there anyone that can tell me why libmap.dll is teasing me?
Milo van der Linden
<a href="http://somafm.com/"><img
src="http://somafm.com/linktous/450x25sfm1.gif" alt="SomaFM" border=0
width=450 height=25 ></a>
