FWTools 1.3.6 using mapserver 5.0.0-beta4
Milo van der Linden mlinden at ZEELANDNET.NL
Wed Sep 12 18:09:23 EDT 2007
Thank you Frank!
Would it be a good idea to set up a mapserver installer that is
specifically for IIS? I would love to maintain that particular one and
testdrive new versions for it.
I will see if I can find an installer tool that can also script IIS
settings at forehand.
To be continued...
Frank Warmerdam schreef:
> mlinden at zeelandnet.nl wrote:
>> Frank,
>> Thank you for the response, I understand your concern and will keep
>> it in
>> mind. For now this is at least a working situation under IIS, which on
>> itself is tricky enough allready. The enduser however is stricly a
>> microsoft minded firm and Apache was no option so WAMP or ms4w was no
>> option.
>> Basically the situation that I now have is a FWtools that is a stripped
>> ms4w installation without apache and mysql, but with the proj and gdal
>> definitions from FWTools.
> Milo,
> I certainly imagine that a stripped MS4W should be usable under IIS.
> And likely FWTools's mapserver should work under IIS. I'm not arguing
> about
> that.  Just warning on the dangers of mixing mapscript dll's from MS4
> with
> FWTools mapserver core.
> Of course, anything that works for you is fair game as long as it doesn't
> impose a support burden on others.
> Best regards,
Milo van der Linden
skype: milovanderlinden <skype:milovanderlinden?add>
mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie in dit bericht reflecteert mijn persoonlijke mening en
niet die van een bedrijf of instantie. Aan de informatie kunnen geen
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bij het betreffende
medium behorende voorwaarden. The information in this message reflects
my personal opinion and not that of a company or public body. All rights
reserved.If this message is contained in a mailing-list or community,
the rights on the medium are automatically adapted.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070913/27e42917/attachment.html
