Labelangleitem question
thomas bonfort
thomas.bonfort at GMAIL.COM
Thu Sep 13 06:10:08 EDT 2007
you can use a custom query on your database
DATA "the_geom from
(SELECT gid, nom, the_geom, (-angle) AS inv_angle FROM troncon_route)
as foo using unique gid"
and then use
ANGLE [inv_angle] in your label block
tb
On 9/13/07, Stéphane RIFF <stephane.riff at cerene.fr> wrote:
> Hello,
> I want to invert the sign of the field I want to use in
> layer->labelangleitem.
> I don't want to it in the database because the information are sent by gps.
> I want to know if it's possible do it on the fly with mapscript and how
> (expression in the labelangleitem property ???) ?
> Thanks
> Steff
