FILTER slow
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Thu Sep 13 07:00:29 EDT 2007
Stephan Holl wrote:
>> FILTER ([adr_id] IN '6446,6366,6483,...')
> Thanks for the tip, but unfortunately it does not solve my problem. The
> filter does not get applied, it does not show up at all with your
> syntax above.
That's weird, this should indeed work and was confirmed the other day by
Lars-Göran Edholm on this mailing list. What Mapserver version are
working on? This is a shapefile layer, right? Are you sure you've got it
right? Notice the quotes around the comma-separated values (no space
between the values)! You could also try to do a string comparison which
might be necessary if adr_id is not a purely numerical field:
FILTER ('[adr_in]' IN '6446,6366,6483')
In this case you just quote the field as well.
HTH,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
