Segmentation fault - mapserver - postgis
Bengt Nilsson
bengt.nilsson at COMBITECH.SE
Thu Sep 13 08:25:14 EDT 2007
I'm trying to run mapserver as a static fastcgi (WMS)application but gets
Segmenttaion fault every second time I request a map from the server. After
that, the fastcgi server is restarted and works for one request again, and so
on..
My configuration is Apache 2.2.6, mod_fastcgi 2.4.2, mapserver 4.10.0,
postgis 1.2.1, postgresql 8.1.4
For debug purposes I have stripped my mapfile to just contain a single layer.
The postgresql serverlog for the first request is:
LOG: 00000: statement: select substring(version() from 12 for (position('on'
in version()) - 13))
LOG: 00000: statement: select attname from pg_attribute, pg_constraint,
pg_class where pg_constraint.conrelid = pg_class.oid and pg_class.oid =
pg_attribute.attrelid and pg_constraint.contype = 'p' and pg_constraint.conkey
[1] = pg_attribute.attnum and pg_class.relname = 'hamnar' and
pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null
LOG: 00000: statement: BEGIN
LOG: 00000: statement: DECLARE mycursor BINARY CURSOR FOR
SELECT "hamn"::text,asbinary(force_collection(force_2d
(the_geom)),'NDR'),gid::text from hamnar WHERE the_geom && setSRID('BOX3D
(12.3070307010819 55.6344639852787,13.7573413069622
56.2846738509944)'::BOX3D, find_srid('','hamnar','the_geom') )
LOG: 00000: statement: FETCH ALL in mycursor
LOG: 00000: statement: CLOSE mycursor
------------ and for the second, failing, request
WARNING: 25001: there is already a transaction in progress
LOG: 08P01: unexpected EOF on client connection
The Apache error log, for the failing request, says:
[Thu Sep 13 10:06:47 2007] [error] [client 10.3.226.74] FastCGI:
server "/srv/www/fcgi-bin/sjb-wms2" stderr: msConnPoolRequest
(Hamnar,user=postgres password=xxxxxx dbname=yyyy host=localhost) -> got
0x81c4568
server "/srv/www/fcgi-bin/sjb-wms2" stderr: msPOSTGISLayerFreeItemInfo
called
server "/srv/www/fcgi-bin/sjb-wms2" stderr: msPOSTGISLayerInitItemInfo
called
server "/srv/www/fcgi-bin/sjb-wms2" stderr: msPOSTGISLayerWhichShapes
called
msPOSTGISLayerRetrievePGVersion(): query = select substring(version() from
12 for (position('on' in version()) - 13))
msPOSTGISLayerRetrievePGVersion: Version String: 8.1.4
[Thu Sep 13 10:06:47 2007] [error] [client 10.3.226.74] FastCGI: incomplete
headers (0 bytes) received from server "/srv/www/fcgi-bin/sjb-wms2"
[Thu Sep 13 10:06:47 2007] [warn] FastCGI: server "/srv/www/fcgi-bin/sjb-
wms2" (pid 7817) terminated due to uncaught signal '11' (Segmentation fault)
wms2" restarted (pid 7922)
msPOSTGISLayerRetrievePGVersion(POSTGISLayerOpen called datastatement:
the_geom from hamnar
The mapfile for the actual layer is like this
LAYER
NAME Hamnar
METADATA
wms_title "Hamnar" ##required
wms_srs "EPSG:2400 EPSG:4326 EPSG:9804"
wfs_title "Hamnar" ##required
END
DUMP TRUE
TYPE POINT
STATUS ON
DEBUG ON
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=xxxxxx dbname=yyyyy
host=localhost"
DATA 'the_geom from hamnar'
PROCESSING "CLOSE_CONNECTION=DEFER"
PROJECTION
"init=epsg:4326" ##recommended
END
MINSCALE 0 # Set by merge script
LABELITEM "hamn"
CLASS
NAME Hamnar_CLS
STYLE
SYMBOL 'circle'
COLOR 136 152 139 # Set by merge script, S52 CHGRD (Gray)
SIZE 8
END
STYLE
SYMBOL 'circle'
COLOR 238 90 108 # Set by merge script, S52 CHRED (Red)
SIZE 5
END
LABEL
TYPE truetype
FONT 'arial'
COLOR 7 7 7 # Set by merge script, S52 CHBLK (Black)
SIZE 10
POSITION ul
END
END
END
I would appreciate if somebody could give me a hint of what's causing the
error.
/Regards Bengt
