Question about Labels
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Sep 13 10:41:17 EDT 2007
Jelmer Baas wrote:
> Hmm, so this means I'll have to detect whether or not a .TAB file has a
> labels or not? I'm not sure if this would be per item, or per .TAB file
> / layer?
Not just that. You need to detect whether a TAB file has *only* labels
in it. Until ticket 2311 is fixed, any object that is not of type TEXT
will trigger the error that you got.
> Also, I don't think this detection can be done in MapServer, right?
> Maybe in MapBasic... Would you happen to have any ideas about that, too?
Well, there is no simple flag to turn on in MapServer if that's what
you're looking for.
I know that the information is available in the header of the .MAP files
of TAB datasets, but it's not easily accessible with any tool. Maybe in
MapBasic, I don't know.
The MITAB library (http://mitab.maptools.org/) has access to that
information in the TABMAPHeaderBlock C++ class, but you'd need to write
custom C++ code to get it. Well the output of MITAB's "tabdump -a
file.tab" dumps the values of these members so you could also use "grep"
on that (look for m_numPointObjects, m_numLineObjects,
m_numRegionObjects and m_numTextObjects).
A simpler option could be to convert the files to MIF and do an
automated search using a text editor or some text processing tool... but
even that's not that simple.
The best of course is to know your data: in that case you'd know which
files contain labels and which ones don't. We'll forgive you for not
knowing your data if you tell us you're a programmer and not a
geographer. ;-)
Daniel
Daniel Morissette
http://www.mapgears.com/
