antialias lines
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at GMAIL.COM
Thu Sep 13 12:43:19 EDT 2007
Hi Bailey.
To give width to a cartoline symbol you need to use the SIZE property of
STYLE element instead of WIDTH.
IMAGETYPE png24
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
SYMBOL
NAME 'cartoline'
TYPE cartoline
LINECAP round
LINEJOIN round
LINEJOINMAXSIZE 3
END
LAYER
NAME "Contours"
STATUS on
TYPE LINE
DATA "Contours"
SYMBOLSCALE 24000
TRANSPARENCY alpha
CLASS
STYLE
COLOR 000 000 000
SYMBOL "cartoline"
ANTIALIAS TRUE
SIZE 3
END
END
END
Rodrigo.
On 9/12/07, Bailey Landress <bailey at texassabal.com> wrote:
> Trying to fix jagged lines. See anything wrong with the Mapfile below?
> When I change IMAGEMODE to RGBA the background of my map turns
> black. Also
> if I take out SYMBOL "cartoline" from the Style tag under Layer, I do
> not
> see any change in regard to antialiasing. Any help would be greatly
> appreciated. Thanks.
> MapServer version 4.10.2
> In MAP:
> IMAGETYPE png24
> OUTPUTFORMAT
> NAME png24
> DRIVER "GD/PNG"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> SYMBOL
> NAME 'cartoline'
> TYPE cartoline
> LINECAP round
> LINEJOIN round
> LINEJOINMAXSIZE 3
> END
> LAYER
> NAME "Contours"
> STATUS on
> TYPE LINE
> DATA "Contours"
> SYMBOLSCALE 24000
> TRANSPARENCY alpha
> CLASS
> STYLE
> COLOR 000 000 000
> SYMBOL "cartoline"
> ANTIALIAS TRUE
> WIDTH 2
> END
> END
> END
> Bailey
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070913/a04a5d17/attachment.html
