Segmentation fault - mapserver - postgis
Frank Warmerdam warmerdam at POBOX.COM
Fri Sep 14 08:41:12 EDT 2007
Nilsson Bengt wrote:
>  Hi,
> I'm not sure that it's a fastcgi problem.
> As you can see from the postgresql log, postgresql reports a
> warning: 'WARNING:  25001: there is already a transaction in progress'.
> The cause of that, I guess, is that mapserver, in mappostgis.c, sends
> (another) 'BEGIN'. During the first call it also sent a BEGIN. In
> mappostgis.c
> there is a check on the outcome of the BEGIN (if(!result ||
> PQresultStatus
> (result) != PGRES_COMMAND_OK) { ) and I guess that it won't be OK
> because
> of the warning.
> Digging around in the postgresql.conf file gave me an idea of changing
> the '#client_min_messages = notice' to 'client_min_messages = error'. As
> I
> understand that means that postgresql won't report warnings back to the
> client, mappostgis, and thus the test won't fail.
> I haven't got any 'Segmentation faults' from the application when
> running it as a static server since my change so I guess I'm on the
> right track.
> I wonder why mapserver sends repeating BEGINs and no ENDs. I
> can't find any code for sending an END. Normally, no fastcgi with
> persistant
> connections, it won't matter since I guess that a closed connection also
> means 'END'.
Bengt,
Good analysis!
This should certainly be filed as a bug report and I'd appreciate
being added in the cc: list.  Likely it should be primarily assigned
to whoever owns the postgis component.
I classify this as loosely a fastcgi problem since it is a problem
that would only come out in fastcgi use (or perhaps long running
mapscript applications).
I *did* use fastcgi with postgis a few years ago so either things
have regressed or there is some specific aspect of your configuration
that tickles the problem.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
