Map-tile edge rendering issue
Christopher Schmidt crschmidt at METACARTA.COM
Fri Sep 14 15:40:49 EDT 2007
On Fri, Sep 14, 2007 at 11:40:25AM -0700, Chris Hodgson wrote:
> I see that someone else has already documented something closely related
> to this issue:
> http://crschmidt.net/blog/archives/154/mapserver-rendering-bug/
> And that it has already been solved in tilecache by adding a buffer
> around the meta-tiles during rendering - but I don't think that solution
> will help with the single-pixel-wide line. Meta-tiling and/or increasing
> the size of the tiles would reduce the likelihood of this happening, but
> I don't think they could prevent it.
It would prevent it, because the problem only presents itself at tile
edges -- and the data from MapServer no longer *has* any visible tile
edges in a meta-tiled TileCache instance. To see similar behavior to
TileCache metatiling, set the 'gutter' option on your WMS layer to '15'
or something similar (see http://openlayers.org/dev/examples/gutter.html)
and I bet you'd see the problem disappear.
> Rendering oversize tiles/meta-tiles
> and cropping them wouldn't have any effect, unless you were using
> anti-aliasing, in which case the problem might be reduced to the line
> getting more faint as it crossed the edge, but still I don't think that
> the line would be properly rendered.
If you're not convinced, try the gutter option. If that doesn't fix it,
you'd be right -- but I bet it will.
> I suppose this might be considered a minor issue because of how rarely
> one would expect to have their lines be nearly parallel to and cross the
> tile boundaries, but I've actually seen that it can happen on just about
> any line that crosses a tile boundary at an acute angle.
I certainly don't consider this bug to be minor issue, but I wrote code
to fix the problem, so I would assume that's obvious ;)
Regards,
Christopher Schmidt
MetaCarta
