Which Projection to use?
LITTLE Nelson nelson.little at TENIX.COM
Mon Sep 17 23:27:29 EDT 2007
David,
Thanks for your reply. What PROJECTION info do I specify and what values
do I give that data?
I see in the mapfile reference page the examples either reference a
projection from the epsg file (which one would I use?) or supply the
values for proj, ellps, datum.
I don't want my x-y data to be projected any differently to how it is
presented in the map files.
Cheers,
Nelson
-----Original Message-----
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Monday, 17 September 2007 11:37 PM
To: LITTLE Nelson; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] Which Projection to use?
If all of your data is in the same projection, you don't need to define
projections in your map file.
One exception is that if you are serving the data up as a WMS or WFS,
you will need to define MAP and LAYER level projections.  You will
likely also need to add metadata at the LAYER and MAP? level that
includes information about the projection.
David.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of LITTLE Nelson
Sent: Monday, September 17, 2007 1:42 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Which Projection to use?
Hi all,
I have shape files which are in x,y coordinate form (units of meters)
and didn't think I needed any projection information because I was
dealing with such a small area, thus never defined any PROJECTION info
in my map file. Now I am getting the following error:
[MapServer Error]: _msProcessAutoProjection(): WMS/WFS AUTO PROJECTION
must be in the format 'AUTO:proj_id,units_id,lon0,lat0' (got '').
I gather from the error message that I need to define at least a map
level projection entry, but I am not sure what I should use?
Any help much appreciated
Cheers,
Nelson
Disclaimer :
The contents of this e-mail including any attachments are intended only
for the person or entity to which this e-mail is addressed.  If you are
not, or believe you may not be, the intended recipient, please advise
the sender immediately by return e-mail, delete this e-mail and destroy
any copies. Tenix does not warrant nor guarantee that this email
communication is free from errors, virus, interception or interference.
Disclaimer :
for the person or entity to which this e-mail is addressed.  If you are not,
or believe you may not be, the intended recipient, please advise the sender
immediately by return e-mail, delete this e-mail and destroy any copies.
Tenix does not warrant nor guarantee that this email communication is free
