5.0+AGG Compile under Slackware
Gregor Mosheh gregor at HOSTGIS.COM
Tue Sep 18 11:22:05 EDT 2007
> If you use the static makefiles that come with AGG, then you need to add
> this. I think it is listed in the trac ticket on building AGG.
Actually, the ticket I saw at
http://trac.osgeo.org/mapserver/ticket/2215 doesn't mention PIC. I did
use PIC while building AGG, and am still getting that "defined in
discarded section" `problem.
I can send the entire log of both builds, if it would be more helpful
than annoying. :)
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
