Legend problem in MapServer 5.0
John Cole john.cole at UAI.COM
Fri Sep 21 10:42:02 EDT 2007
I have the same issue:  using a MS4 mapfile, cgi mapserver on windows (ms4w
2.2.6), with and without AGG, I'm getting a little black box for the legend.
Same map file on 4.10 and the legend works.
I've tried the DENOM additions and it doesn't appear to effect it.
MS4  http://www.nabble.com/file/p12822994/CropperCapture%255B2%255D.png
MS5  http://www.nabble.com/file/p12822994/CropperCapture%255B3%255D.png
I've attempted to attach images (I'm using nabble).  So hopefully you can
see what I'm getting.
Thanks,
John
Steve Lime wrote:
> If you try changing to the new keywords MINSCALEDENOM and MAXSCALEDENOM
> does the
> problem persist? (the old keywords should work)
> Also, are we talking the CGI, MapScript (if so, which flavor?) or ????
> Steve
>>>> On 9/19/2007 at 1:11 PM, in message
> <12783108.post at talk.nabble.com>, Frode
> Wiseth Jørgensen <frodewj at GMAIL.COM> wrote:
>> Hey!
>> I have just upgraded to MapServer 5.0, and there seems to be a
> little
>> problem.
>> When I use MAXSCALE and MINSCALE on a layer, the class won’t show
> up in
>> legend.
>> Using the same mapfile on a previous version of MapServer,  the class
> shows
>> up in legend.
>> Any ideas?
>> Regards,
>> Frode
>> View this message in context:
> http://www.nabble.com/Legend-problem-in-MapServer-5.0-tf4482729.html#a1278310
>> 8
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Legend-problem-in-MapServer-5.0-tf4482729.html#a12822994
