Legend problem in MapServer 5.0
John Cole
john.cole at UAI.COM
Fri Sep 21 17:54:10 EDT 2007
My WMS getLegendGraphic calls are not working however.
MS4: http://www.nabble.com/file/p12830510/CropperCapture%255B4%255D.png
MS5: http://www.nabble.com/file/p12830510/CropperCapture%255B5%255D.png
This seems like a big issue to me :-) Was there a change in the LEGEND that
needs to be made for MS5?
Thanks,
John
Frode Wiseth Jørgensen wrote:
> Hey,
> I've tested with MAXSCALE/MINSCALE and MINSCALEDENOM/MAXSCALEDENOM in
> - PHP MapScript
> - CGI
> - CSHARP
> but there is still no legend.
> Have also tested using MAXSCALE/MINSCALE and MINSCALEDENOM/MAXSCALEDENOM
> on both LAYER and CLASS -> no legend.
> However..connection to the layer through WMS gives me legend
> (LegendGraphic).
> Any ideas??
> Steve Lime wrote:
>> If you try changing to the new keywords MINSCALEDENOM and MAXSCALEDENOM
>> does the
>> problem persist? (the old keywords should work)
>> Also, are we talking the CGI, MapScript (if so, which flavor?) or ????
>> Steve
>>>>> On 9/19/2007 at 1:11 PM, in message
>> <12783108.post at talk.nabble.com>, Frode
>> Wiseth Jørgensen <frodewj at GMAIL.COM> wrote:
>>> Hey!
>>> I have just upgraded to MapServer 5.0, and there seems to be a
>> little
>>> problem.
>>> When I use MAXSCALE and MINSCALE on a layer, the class won’t show
>> up in
>>> legend.
>>> Using the same mapfile on a previous version of MapServer, the class
>> shows
>>> up in legend.
>>> Any ideas?
>>> Regards,
>>> Frode
>>> View this message in context:
>> http://www.nabble.com/Legend-problem-in-MapServer-5.0-tf4482729.html#a1278310
>>> 8
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Legend-problem-in-MapServer-5.0-tf4482729.html#a12830510
