Legend problem in MapServer 5.0
John Cole john.cole at UAI.COM
Tue Sep 25 07:39:02 EDT 2007
I have observed that legends do not work with existing mapfiles;  all of
which have MIN/MAX SCALES set.  It is broken using mode=browse, mode=legend
and GetLegendGraphics.  Little black boxes are returned for both GD and AGG
renderer's.  The same map, with the same extents has a working legend using
MS4.
See:
MS4: (working legend)
http://pmap1.hud.uai.com/cgi-bin4/mapserv.exe?map=/mapserver/gdt/main4.map&BBOX=-86.778940,34.651680,-86.718060,34.697320&mapxy=-86.7485%2034.6745&scale=24000.000000&layers=bound+hydro+landmark+roads+base_anno+hydro_anno+roads_anno+landmark_point+city&mode=browse
MS5: (broken legend)
http://pmap1.hud.uai.com/cgi-bin/mapserv.exe?map=/mapserver/gdt/main4.map&BBOX=-86.778940,34.651680,-86.718060,34.697320&mapxy=-86.7485%2034.6745&scale=24000.000000&layers=bound+hydro+landmark+roads+base_anno+hydro_anno+roads_anno+landmark_point+city&mode=browse
I do not have any mapfiles without MIN/MAX scales ready to test at the
moment.
John
tbonfort wrote:
> could all of you having these problems summarize , for each specific
> case if necessary (i.e. html legends or wms getlegendgraphics), if the
> problem is specific to agg rendering or also occurs using gd.
> there's also http://trac.osgeo.org/mapserver/ticket/2284 on this, so
> it is a known issue that legending is buggy if using agg
> cheers,
> tb
View this message in context: http://www.nabble.com/Legend-problem-in-MapServer-5.0-tf4482729.html#a12877729
Sent from the Mapserver - User mailing list archive at Nabble.com.
