[mapserver-users] MapServer 4.8.3: MapScript setProjection
Daniel Morissette
dmorissette at mapgears.com
Wed Apr 2 11:44:29 EDT 2008
Simon,
Are you also setting the "wms_srs" metadata in the map's web object? If
not then perhaps try setting the "wms_srs" metadata in the web object to
"EPSG:27700" and see if that helps.
Daniel
Simon Greig wrote:
> Hi,
> We have made the changes to remove the explicit layer setProjection and
> allow each layer to inherit the projection from its map.
> However for some vector layers we consistently get:
> "Layer must have an EPSG or AUTO projection code (in its PROJECTION
> object or wms_srs metadata)"
> A layer either works or does not work, but 30% of our layers fail with
> this error. Also layers that work or fail differ between environments.
> We don't use a map file for layer data (just for mapObj config) as all
> of our layer configurations are stored in a database. Our WMS_LAYERS
> table stores all of the data that you would normally see within the
> LAYERS section of a mapfile.
> I have checked the PROJECTION setting and for all layers it is set to
> "init='epsg:27700'".
> Our code manually constructs mapObj and layerObj objects taking the
> configuration from our config database.
> When our code constructs the layerObj JNI objects it checks the
> PROJECTION value from the database and if the DB value is the same as
> the mapObj projection then the code skips the layerObj.setProjection
> because it assumes that the layer will inherit the projection from the
> mapObj used in the constructor of the layerObj.
> None of the layers in the list are WMS layers and the layers that fail
> are all going to our Oracle Spatial database.
> I have asked the database team to investigate the differences between
> layers that work and fail in the same environment and layers that work
> in one environment and fail in another. I have inspected the
> development database and a I cannot see anything different between a
> layer that works and one that does not.
> e.g. If I simulate the mapfile syntax for our layers for the benefit of
> the email, if we had defined our layers in the mapfile they would look
> like this:
> LAYER
> NAME "2001UrbanAreas(Census)"
> CONNECTION "<usr>/<pwd>@SPR01"
> STATUS ON
> TYPE POLYGON
> DATA "GEOMETRY FROM OTHERAGENCIES.DCLG00000001 USING SRID 81989"
> MAXSCALE 99999999
> MINSCALE 0
> TRANSPARENCY 60
> PROJECTION "init=epsg:27700"
> END
> LAYER
> NAME "EnglishHeritageRegions"
> STATUS ON
> TYPE POLYGON
> DATA "GEOMETRY FROM OTHERAGENCIES.ENGH00000001 USING SRID 81989"
> MAXSCALE 99999999
> MINSCALE 0
> TRANSPARENCY 60
> END
> 2001Urban layer fails with the projection error, the
> EnglishHeritageRegions works for the exact same bounding box/scale.
> We have not applied the METADATA change as the layers are not external
> WMS layers and presumably setting the METADATA wms_srs would provide the
> same effect as calling layerObj.setProjection?
> If we restore the code to setProjection for every layer then the errors
> go away - but our performance goes down.
> Does any of this description allow anyone to suggest areas that I should
> get the database team to focus on?
> Any advice appreciated :-)
> Simon
> /Unless stated otherwise above:
> IBM United Kingdom Limited - Registered in England and Wales with number
> 741598.
> Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6 3AU/
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
