[MAPSERVER-USERS] Route Layer - Transparency
P Kishor
punk.kish at gmail.com
Thu Apr 3 11:55:20 EDT 2008
On 4/3/08, Ritesh Ambastha <group.ritesh at gmail.com> wrote:
> I have solved this issue. People with similar kind of problem can reach me
> for help.
that is very kind, but a more effective way is to post a reply in the
same thread with the solution. That way it will get archived, indexed,
and available to those who might really search the archives before
asking the same question all over again.
You can also write a phrase like so in your solution --
*SOLVED* or *SOLUTION*, or something like that.
it might marginally increase the chances of it being discovered in a
later search.
> Regards,
> Ambastha
> Ritesh Ambastha wrote:
> > Hello Ka-mappers,
> > I am successfully showing routing on my map using ka-map routing.
> > I am unable to set TRANSPARENCY to this route layer.
> > I have two map files,
> > a) main.map (consists of many layers)
> > b) route.map (consists of only one route layer)
> > In main.map, I am able to play with transparency. But, I am unable to set
> > transparency to route.map.
> > I am using GD/PNG driver, and png24 as outputformat.
> > Your suggestions will be highly appreciated.
> > Regards,
> > Ambastha
> View this message in context: http://www.nabble.com/Route-Layer---Transparency-tp16442995p16467762.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Puneet Kishor http://punkish.eidesis.org/
Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
