[mapserver-users] Unable to access Grid Object (GridObject) via
C# MapScript interface (related to bug 1980)
Tamas Szekeres
szekerest at gmail.com
Fri Apr 4 17:42:16 EDT 2008
2008/4/4, Hulbert, Brian <brian.hulbert at linquest.com>:
> I was using 4.10.1 [per a call to mapscript.msGetVersion()].
> I now switched to 5.0.2 (once I got the complete list of DLLs) and it does
> in fact have the updateFromString() method. Can you point to a document
> which talks about the syntax to use in the string to supply? Specifically,
> I will be trying to change the LABELFORMAT of the grid object within my grid
> layer.
It should be the same as you write it in your mapfile, like for example:
"GRID\nLABELFORMAT \"%g°\"\nEND\nEND"
or something like this.
Best regards,
Tamas
