[MAPSERVER-USERS] how mapserver handles different datum projections
DNC
dncarreira at gmail.com
Sat Apr 5 16:26:48 EDT 2008
Hi all.
Can anyone clarify how mapserver handles different datum in the map
projection and in the layers projection when serving a wms service?
Does MS apply datum transformations? If not, can it be done somehow without
converting the layers?
In my case I'm working with vector data, and have defined a map projection
using "init=epsg:code" syntax. Then at the layer level I use the same syntax
to declare the projection the data is in.
And finally I want my WMS service to be published in 3 different datum and
for that I advertise several epsg codes in the "wms_srs" metadata entry.
I'm noticing a shift in images produced by MS that indicate a datum shift is
not being applied. What can be done?
Thanks,
Duarte
View this message in context: http://www.nabble.com/how-mapserver-handles-different-datum-projections-tp16517601p16517601.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
