[mapserver-users] compiling on windows
Tamas Szekeres
szekerest at gmail.com
Mon Apr 7 17:24:23 EDT 2008
Have you been compiling using the MSVC_VER=1400 option?
I confirm the current SVN version compiles on Win2003 for either the Win32
or the Win64 platforms.
Here are the expected outputs of the Win32 and Win64 compilations:
http://buildbot.osgeo.org:8504/builders/szekerest-vc80-full/builds/58/steps/
nmake/logs/stdio
http://buildbot.osgeo.org:8504/builders/szekerest-vc80x64-full/builds/57/ste
ps/nmake/logs/stdio
Best regards,
Tamas
_____
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Florin A.
Sent: Monday, April 07, 2008 10:54 PM
To: Frank Warmerdam
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] compiling on windows
Hi Frank,
I forgot the rest....
C:\projects\regex-0.12\regex.c(4079) : warning C4018: '>=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4110) : warning C4018: '<=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4123) : warning C4018: '<=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4293) : warning C4018: '>=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(3771) : warning C4101: 'destination' :
unreferenced local variable
C:\projects\regex-0.12\regex.c(3918) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(3971) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4110) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4123) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4876) : warning C4996: 'errcode' was declared
deprecated
C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\crtdefs.h(506)
: see declaration of 'errcode'
Message: 'This name was supported during some Whidbey pre-releases.
Instead, use the standard name errno_t.'
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'preg' : name in formal
parameter list illegal
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf' : name in
formal parameter list illegal
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf_size' : name in
C:\projects\regex-0.12\regex.c(4877) : error C2055: expected formal
parameter list, not a type list
C:\projects\regex-0.12\regex.c(4877) : error C2082: redefinition of formal
parameter 'errcode'
C:\projects\regex-0.12\regex.c(4885) : warning C4996: 'errcode' was declared
deprecated
C:\projects\regex-0.12\regex.c(4885) : error C2059: syntax error : 'type'
C:\projects\regex-0.12\regex.c(4893) : error C2275: 'errcode' : illegal use
of this type as an expression
C:\projects\regex-0.12\regex.c(4910) : warning C4996: 'strcpy' was declared
deprecated
Message: 'This function or variable may be unsafe. Consider using
strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRE
CATE. See online help for details.'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
On Mon, Apr 7, 2008 at 2:03 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
Florin A. wrote:
Hello,
I'm trying to compile MapServer on Windows Server 2003. I followed all the
instructions on http://mapserver.gis.umn.edu/docs/howto/win32_compiling and
I'm stuck with regex errors. The errors are the same as this post
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg15996.html
I'm compiling with nmake from Microsoft Visual Studio 8
I also tried compiling with the buildkit from
http://download.osgeo.org/buildkit/ and got the same errors.
regex.c
C:\projects\regex-0.12\regex.c(768) : warning C4018: '<' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(1953) : warning C4018: '>' : signed/unsigned
mismatch
I tried the correction mentioned for the regex.c file:
//extern void printchar ();
void printchar( int i ) {}
This made no difference. I also tried with the win32 regex distribution from
http://people.delphiforums.com/gjc/gnu_regex.exe and again, exactly the same
errors.
Has anybody else encountered this regex error? Shouldn't nmake work with no
problems on the buildkit ?
Florin,
The above are just warnings. I would encourage you to just ignore them
and proceed.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
<http://pobox.com/%7Ewarmerdam>
and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080407/52810165/attachment-0001.html
