[mapserver-users] help: load a static map
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Apr 9 17:35:18 EDT 2008
Hi Marco: The name of the States layer in your mapfile is 'comuni' yet
you're turning on
a layer with a different name (&layer=states) in your URL. I imagine
that's the problem.
Steve
>>> On 4/9/2008 at 10:47 AM, in message
<11933de9003.marco.sileri at virgilio.it>,
<marco.sileri at virgilio.it> wrote:
> Hi
> I'm a student and I’m starting my first application of MapServer
> with my own data following the tutorial and I already have the
> following problem.
> I have a very simple  shape data  in
> geographic/WGS84 and also UTM/WGS84 format; I have picked the
extension
> using ARCGIS and I have tried a static visualization of my map as it
is
> shown in the first example of the tutorial.
> MAP
>   IMAGETYPE      PNG
> #   EXTENT         -97.348976 41.619778 -82.122902 49.385620  #geo
> states
>      EXTENT         12.238976 41.619778 13.122902 49.385620
> #geo rieti
> #   EXTENT         73306.04 -295414.39 1501200.05
> 614634.59   #laea states
> #   EXTENT         280000.0 4660000.0 376000.0
> 4735000.0     #UTM/WGS84 rieti
>   SIZE           1000 1000
> SHAPEPATH      "/ms4w/apps/marco/data"
>   IMAGECOLOR     255 255 255
> # Start of LAYER DEFINITIONS
>   LAYER # States polygon
> layer begins here
>   NAME         comuni
>   DATA         comuni_rieti_ll
>   STATUS       OFF
>   TYPE         POLYGON
>   CLASS
>       NAME
> "comuni"
>       STYLE
>       COLOR        232 232 232
>       OUTLINECOLOR
> 32 32 32
>      END
>     END
>   END # States polygon layer ends here
> I
> have tried the following things:
> - load my data  using the geographic
> coordinates (and corresponding extension);
> UTM/WGS84 coordinates (and corresponding extension);
> - read the data
> through  the html-page or entering the URL  (http://localhost/cgi-
> bin/mapserv.exe?map=/ms4w/apps/marco/htdocs/example1-1.
> map&layer=states&mode=map)
> I always don’t have any error, but I only
> see the window in which the data should be visualised.
> It’s looks
> like the extension is wrong, but  I have checked my shape with ArcGis
> and also with Ogrinfo ….
> INFO: Open of `comuni_rieti_ll.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: comuni_rieti_ll
> Geometry: Polygon
> Feature Count: 73
> Extent: (12.436251, 42.089346) -
> (13.409627, 42.740986)
> Layer SRS WKT:
> GEOGCS["GCS_WGS_1984",
>     DATUM
> ["WGS_1984",
>         SPHEROID["WGS_1984",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
>     UNIT["Degree",0.0174532925199433]]
> AREA:
> Real (15.3)
> PERIMETER: Real (15.3)
> COD_AMM: Integer (9.0)
> COMUNE:
> String (35.0)
> PROVINCIA: String (20.0)
> CS_15: Integer (2.0)
> COD_REG:
> Integer (3.0)
> COD_PRO: Integer (3.0)
> COD_COM: Integer (3.0)
> What can
> be wrong and what other  can be done to solve the problem?
> Can
> anybody, please, help me?
> Bye Marco
> mapserver-users at lists.osgeo.org
