[mapserver-users] Drawing a circle on a map
    Sucharita Samuel
    iworktech.sucharita at gmail.com
    Sat Apr 12 06:05:27 PDT 2008
Thanks Kishore.
I think I should have elaborated my query. I need to create a shapeObject
which will hold the circle to be drawn (That part is done). This shapeobject
then is to be rendered onto the mapobject which is already present on the
web page. The only problem I am facing is even though my circle is created,
it is not getting rendered onto the web page over the map. Can you please
help me with this.
Thanks,
Sucharita
On Sat, Apr 12, 2008 at 5:53 PM, P Kishor <punk.kish at gmail.com> wrote:
> On 4/12/08, Sucharita Samuel <iworktech.sucharita at gmail.com> wrote:
> > Hi all,
> >         I want to draw a circle of 5 km radius around the point I click
> on
> > the map. I am using C# mapscript. Even if you can help me with the php
> code,
> > it will be of great help.
> a circle is one of the easiest geometric primitives you can draw.
> Capture the mouse click and you've got your center. Use a standard
> circle equation and you've got what you want. Google for how to draw a
> circle.
> > Thanks in advance.
> > Regards,
> > Sucharita
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080412/69635a94/attachment.htm>
More information about the MapServer-users
