[mapserver-users] ms4w mapserver 5.0 can't display raster image.
ptang83 at yahoo.com ptang83 at yahoo.com
Mon Apr 14 01:23:19 EDT 2008
Jacob
I used the shp2img tool and it is able to generate a png file. I can view this generated image file and it looks good.
C:\Program Files\ms4w\tools\mapserv>shp2img -m "C:\Program Files\ms4w\Apache\htdocs\nitelti020l.map" -o test1.png
I have cleaned all tmp dir and I still no changes. while I play with other format data, it refresh no problem. I assume there is no cache issue.
Could it be openlayers issue?
Thanks!
--- On Sun, 4/13/08, Delfos, Jacob <Jacob.Delfos at maunsell.com> wrote:
> From: Delfos, Jacob <Jacob.Delfos at maunsell.com>
> Subject: RE: [mapserver-users] ms4w mapserver 5.0 can't display raster image.
> To: ptang83 at yahoo.com, mapserver-users at lists.osgeo.org
> Date: Sunday, April 13, 2008, 11:40 PM
> Have you tried using shp2img on your mapfile?
> The tricky thing with tiled web-mapping systems is that
> they use
> aggressive caching. Any changes you have made to your
> mapfile would not
> be reflected until you forcibly remove all files from the
> cache of your
> browser. So perhaps you are looking at old images.
> Jacob
> > -----Original Message-----
> > From: ptang83 at yahoo.com [mailto:ptang83 at yahoo.com]
> > Sent: 14 April 2008 12:36
> > To: mapserver-users at lists.osgeo.org; Delfos, Jacob
> can't
> > Sorry for the confusion. I have it untared as
> > C:\oatdir\nitelti020l.tar\nitelti020l.tif
> > I can view it and I am also able to load it in to
> qgis.
> > > From: Delfos, Jacob
> can't
> > > Date: Sunday, April 13, 2008, 10:53 PM
> > > Hi,
> > > It may be worth trying to untar your image. I
> suspect
> > > mapserver *may*
> > > not be able to do this on the fly.
> > > Regards,
> > > Jacob
> > > > From:
> mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On
> > > Behalf Of
> > > > Sent: 14 April 2008 11:41
> > > > Subject: [mapserver-users] ms4w mapserver
> 5.0
> > > can't display
> > > > raster image.
> > > > I used Mapserver + Openlayers + Postgis. I
> can load
> > > shp data
> > > > to postgis and display it without any
> problem.
> > > However,
> > > > somehow I am not able to display any raster
> map even
> > > without
> > > > using postgis. I only see a blank
> rectangular on my
> > > web
> > > > browzer. I wonder whether there is a bug or
> something
> > > I did
> > > > wrong. Thanks in advance..
> > > > I have downloaded ms4w Mapserver and has the
> following
> > > config.
> > > > # Apache 2.2.8
> > > > # PHP 5.2.5
> > > > # mapserv 5.0.2 at /cgi-bin/mapserv.exe
> > > > LOG files show nothing wrong:
> > > > Sun Apr 13 21:57:14
> > > > 2008,12804,127.0.0.1,nitelti020l,3,-0.000000
> > > -90.000000
> > > > 180.000000 90.000000,-1.000000
> -1.000000,,normal
> > > execution
> > > > Sun Apr 13 21:57:14
> 2008,14076,127.0.0.1,nitelti020l,3,-180.000000
> > > -90.000000
> -1.000000,,normal
> > > execution
> > > > MAP file:
> > > > # Map file created from QGIS project file
> C:/Program
> > > > Files/Quantum GIS/nitelti020l.qgs
> > > > # Edit this file to customize for your map
> interface
> > > > MAP
> > > >   NAME nitelti020l
> > > >   # Map image size
> > > >   SIZE 600 600
> > > >   UNITS dd
> > > >   EXTENT -6086744.000000 -5878356.737659
> > > 4278894.138000 7580130.593659
> > > >   PROJECTION
> > > >  #   'proj=longlat'
> > > >   #  'ellps=WGS84'
> > > >   #  'datum=WGS84'
> > > >    # 'no_defs'
> > > > "init=epsg:4326"
> > > >   END
> > > >   # Background color for the map canvas --
> change as
> > > desired
> > > >   IMAGECOLOR 192 192 192
> > > >   IMAGEQUALITY 95
> > > >   IMAGETYPE jpeg
> > > >   OUTPUTFORMAT
> > > >     NAME jpeg
> > > >     DRIVER 'GD/JPEG'
> > > >     MIMETYPE 'image/jpeg'
> > > >     #IMAGEMODE PC256
> > > >     EXTENSION 'jpeg'
> > > >   END
> > > >   # Legend
> > > >   LEGEND
> > > >       IMAGECOLOR 255 255 255
> > > >     STATUS ON
> > > >     KEYSIZE 18 12
> > > >     LABEL
> > > >       TYPE BITMAP
> > > >       SIZE MEDIUM
> > > >       COLOR 0 0 89
> > > >     END
> > > >   END
> > > >   # Web interface definition. Only the
> template
> > > parameter
> > > >   # is required to display a map. See
> MapServer
> > > documentation
> > > >   WEB
> > > >     # Set IMAGEPATH to the path where
> MapServer should
> > > >     # write its output.
> > > >     IMAGEPATH '/tmp/'
> > > >     # Set IMAGEURL to the url that points to
> IMAGEPATH
> > > >     # as defined in your web server
> configuration
> > > >     IMAGEURL '/tmp/'
> > > >     # WMS server settings
> > > >     METADATA
> > > >       'wms_title'
> > > 'nitelti020l'
> > > >       'wms_onlineresource'
> 'http://localhost/cgi-bin/mapserv?map=wms.map&'
> > > >       'wms_srs'
> > > 'EPSG:4326'
> > > >     END
> > > >     #Scale range at which web interface will
> operate
> > > >     # Template and header/footer settings
> > > >     # Only the template parameter is
> required to
> > > display a
> > > > map. See MapServer documentation
> > > >   END
> > > >   WEB
> > > >     LOG
> "c:\tmp\mapserv.log"
> > > >   END
> > > >   LAYER
> > > >     NAME 'nitelti020l'
> > > >     TYPE RASTER
> > > >     DATA
> 'C:\oatdir\nitelti020l.tar\nitelti020l.tif'
> > > >     METADATA
> > > >       'wms_title'
> 'nitelti020l'
> > > >     END
> > > >     STATUS DEFAULT
> > > >     TRANSPARENCY 100
> > > >     PROJECTION
> > > > #    'proj=longlat'
> > > > #    'ellps=WGS84'
> > > > #    'datum=WGS84'
> > > > #    'no_defs'
> > > > "init=epsg:4326"
> > > >     END
> > > >   END
> > > > END
> > > > Raster date download
> http://edcftp.cr.usgs.gov/pub/data/nationalatlas/nitelti020l.tar.gz
> > > > simple open layer code
> > > > <html
> xmlns="http://www.w3.org/1999/xhtml">
> > > >   <head>
> > > >     <style type="text/css">
> > > >         #map {
> > > >             width: 800px;
> > > >             height: 475px;
> > > >             border: 1px solid black;
> > > >     </style>
> > > >     <script
> src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
> > > >     <script
> type="text/javascript">
> > > >         var map, layer;
> > > >         function init(){
> > > >             map = new OpenLayers.Map(
> 'map' );
> > > >             layer = new
> OpenLayers.Layer.MapServer(
> > > "OpenLayers WMS",
> > > "http://localhost/cgi-bin/mapserv.exe",
> > > > {map: 'C:/Program
> > > Files/ms4w/Apache/htdocs/nitelti020l.map'} );
> > > >             map.addLayer(layer);
> > > >             map.zoomToMaxExtent();
> > > >     </script>
> > > >   </head>
> > > >   <body onload="init()">
> > > >     <div
> id="map"></div>
> > > >   </body>
> > > > </html>
> __________________________________________________
> > > > Do You Yahoo!?
> > > > Tired of spam?  Yahoo! Mail has the best
> spam
> > > protection around
> > > > http://mail.yahoo.com
> > > > mapserver-users mailing list
> > > This email and any attachments are intended
> solely for the
> > > named recipient and are confidential. The copying
> or
> > > distribution of them or any information they
> contain by
> > > anyone other than the named recipient is
> prohibited. If you
> > > have received this document in error, please
> notify the
> > > sender and delete all copies from your computer
> system and
> > > destroy all hard copies. It is the
> recipient's
> > > responsibility to check this email and any
> attachments to
> > > this email for viruses before use.
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam
> protection around
> This email and any attachments are intended solely for the
> named recipient and are confidential. The copying or
> distribution of them or any information they contain by
> anyone other than the named recipient is prohibited. If you
> have received this document in error, please notify the
> sender and delete all copies from your computer system and
> destroy all hard copies. It is the recipient's
> responsibility to check this email and any attachments to
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
