[mapserver-users] Problem with MapServer & proj4
Clemiou
clems_mars at hotmail.com
Tue Apr 15 14:30:13 EDT 2008
Hi!
First, excuse me for my English. I'm french and you will find many mistakes in this mail, i'm sure. ^^
I have a little problem with Proj4 and Mapserver. I'm a new user of MS since the last week and I can print some maps without difficulties.
For my student placement, I must provide to the users, the possibility to zoom in, to zoom out & to pan. So, I try OpenLayers.
But I forgot to put PROJECTION items in my mapfile. So I install Proj4 (phpinfo() tell me that it's ok and mapserv -v too).
But when I want print my map, I obtain this message: loadProjection(): Projection support is not available.
I think that he miss a link or something like that because mapserv has been built with --with-proj option. In addition, as I said, I can see SUPPORT=PROJ in the phpinfo() and in the result of masperv -v command.
Thank you for your help and sorry for my poor english.
Sincerely yours
Clement
PS: I give you my files, the mapfile and my php file which use OpenLayers.
mapfile:
## france.map ##
## Fichier au format mapserveur pour afficher la France ##
## Regroupe (normalement ^^) la France entière plus la Corse ##
## Les sources seront au format ECW. ##
## (c) Copyright MIVA Web Editions ##
MAP
PROJECTION
"init=epsg:4326"
END
# Taille de l'image à afficher. En pixels.#
SIZE 700 700
# Paramètres divers; status, chemin des symboles utilisés.#
STATUS ON
SYMBOLSET "/var/www/html/maps/symbols/symbols.sym"
# Etendue spaciale de notre carte. Dans de rare cas, elle #
# est calculée par MapServer. Position de l'image. #
# Pour les fichiers .tif, on trouve des informations la #
# concernant dans le fichier du même nom .tfw. #
# Les paramètres correspondent dans l'ordre à: #
# -MinX,MinY,MaxX,MaxY #
EXTENT 550501 1700039 595100 2644900
# Unité de l'echelle #
UNITS METERS
# Chemin des fichiers sources (ici ECW). #
SHAPEPATH "/var/www/html/maps/data/"
# Partie Web: fourni des informations pour la génération de #
# l'image. #
WEB
TEMPLATE "/var/www/html/OpenLayers-2.6-rc2/examples/mapserver.html"
# Chemin du dossier dans lequel MapServeur va sauvegarder #
# l'image crée. #
IMAGEPATH "/var/www/html/maps/tmp"
# Chemin du dossier dans lequel MapScript viendra lire #
# l'image. /!\ Attention, le chemin doit être indiqué à #
# partir du dossier /html. #
IMAGEURL "/maps/tmp"
END
# Les layers. Ce sont les différentes couches de l'image. #
# Logiquement, une couche pour une partie de France. Nous #
# devrions donc en avoir 11 en comptant la corse. #
# Pour reconstituer notre France, nous allons créer un #
# index qui va gérer les 2 parties. #
# Le layer de la France . #
LAYER
NAME "FRANCE"
TYPE RASTER
STATUS ON
TILEINDEX france.shp
TILEITEM Location
PROJECTION
"init=epsg:27582"
END
# Correspond au fichier qu'il faut charger pour la couche.#
# Dans le cas ou on charge une image à la fois. #
#DATA France.ecw
# On crée une classe pour ce layer. #
CLASS
STYLE
COLOR 110 50 100
OUTLINECOLOR 200 200 200
SYMBOL 0
END # Fin de STYLE FRANCE.
END # Fin de CLASS FRANCE.
END # Fin du LAYER FRANCE.
END # Fin du MAP.
phpfile:
<?php
// Voyage.php //
// www.leguide.aero //
// Partie permettant au visiteur de visualiser son voyage sur la carte. //
// Celui-ci doit pouvoir interagir avec l'utilisateur en lui permettant //
// de choisir et visualiser ses points de départ et d'arrivée. Par //
// ailleurs, le fait de déplacer la carte avec la souris doit se faire //
// dynamiquement. Enfin, le fait de cliquer à un endroit de la carte //
// doit faire centrer ce point au millieu de celle-ci. //
// (c) Copyright MIVA Web Editions //
// Rappelons que le module php_MapScript est chargé par defaut au démarrage. //
// La déclaration de ce chargement se trouve dans le fichier php_mapscript.ini //
// Déclaration de la variable contenant le chemin vers les fichiers .map. //
// MapScript doit le trouver par defaut mais il est plus sur de lui fournir. //
$map_path = "/var/www/html/ms/map_files/";
// On crée un nouvel objet puis on charge dans celui-ci notre fichier .map. //
// La deuxième instruction le dessine et la troisième le sauvegarde dans le //
// répertoire /maps/tmp/ après avoir crée le fichier image correspondant. Par //
// defaut, ce fichier image est au format GIF. //
$mapi = ms_newMapObj($map_path."france.map");
$image = $mapi->draw();
$image_url = $image->saveWebImage();
// Page HTML pour afficher la carte. //
<HTML>
<HEAD>
<TITLE>LeGuide.aero: Préparez votre voyage en toute sérennité... ^^</TITLE>
<LINK rel="stylesheet" href="../OpenLayers-2.6-rc2/theme/default/style.css" type="text/css" ></LINK>
<STYLE type="text/css">
#map {
width: 700px;
height:700px;
border: 1px solid black;
</STYLE>
<SCRIPT src="../OpenLayers-2.6-rc2/lib/OpenLayers.js" ></SCRIPT>
<SCRIPT type="text/javascript">
var lon = 40;
var lat = 40;
var zoom = 20;
var map, layer;
function init()
layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
"http://localhost/cgi-bin/mapserv?map=/var/www/html/ms/map_files/france.map", {layers: 'FRANCE'},
{gutter: 1});
map.addLayer(layer);
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
map.addControl( new OpenLayers.Control.LayerSwitcher() );
</SCRIPT>
</HEAD>
<BODY onload="init()">
<DIV id="map"></DIV>
</BODY>
</HTML>
_________________________________________________________________
Découvrez les profils Messenger de vos amis !
http://home.services.spaces.live.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080415/d4fc6ad7/attachment.html
