[mapserver-users] Any Fedora fc8 64 bit mapserver users out there? [SEC=UNCLASSIFIED]
Tim Bowden tim.bowden at westnet.com.au
Wed Apr 16 22:11:18 EDT 2008
Try running memtest before anything else.  That may isolate the problem
and save a heap of work.
Regards,
Tim
On Wed, 2008-04-16 at 10:32 -0500, Stephen Woodbridge wrote:
> Hi Antti,
> I have heard back from 3-4 other users of 64bit Fedora and none of them
> are having problems like I had. The symptoms I was having are so basic
> that I am beginning to think that they may be hardware memory? related.
> We are wiping that system and installing Debian Etch 64bit on it and
> seeing how that plays. I have been running Debian Sarge on a 64bit dual
> Xeon server for 2 years and have had no problems with 64bit apps or with
> compiling and building any of the GIS stack that I use. If we still have
> problems, then I think we can be assured it is hardware. If we don't.
> I'm not sure what that tells us, but I will probably stick with Debian
> on this box because I have work to do on it and don't have time to
> trouble issues like this.
> I hope this helps,
>   -Steve
> Roppola, Antti - BRS wrote:
> > Hi all,
> > This is pretty timely as we are scoping out new servers and up 'til
> > now I have conciously avoided 64 bit deployments. The abundance of
> > 64 bit platforms seems to have made 64 bit less boutique and less risky.
> > Antti
> > -----Original Message-----
> > From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nahum Castro
> > Sent: Wednesday, 16 April 2008 11:54 AM
> > To: Stephen Woodbridge; mapserver-users
> > Subject: Re: [mapserver-users] Any Fedora fc8 64 bit mapserver users out there?
> > --- Stephen Woodbridge <woodbri at swoodbridge.com>
> > escribió:
> >> Hi,
> >> If you are a Fedora fc8 64 bit mapserver user (or close to that), can
> >> you please contact me off list. I'm having mapserver runtime issues
> >> and just need to compare notes and see what your experiences have
> >> been.
> >> Many thanks in advance,
> >>    -Steve Woodbridge
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > I have mapserver installed on fc8 x86_64 with no problems.
> > I compilled all this software gd, proj4, geos, postgresql, postgis, gdal and grass, then mapserver with php-mapscript and ogc services.
> > All other software was from fedora repositories.
> > I have 2 installations one with intel and the other with AMD both fc8 64.
> > Nahum.
> > Nahum Castro
> > Leon, Guanajuato, Mexico
> > http://www.leon-linux.com
> > e-mail: pedro1_72 [en] yahoo [punto] com
> >       ____________________________________________________________________________________
> > ¡Capacidad ilimitada de almacenamiento en tu correo!
> > No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
> > http://correo.yahoo.com.mx/
> > ------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
> > Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
