[mapserver-users] Connexion between Mapserver & MySql
Till Adams adams at terrestris.de
Fri Apr 18 04:17:29 EDT 2008
Clement,
look on the mapserver homepage, I've sent a mysql/ovf howto document
there last year. It describes step by step what to do.
http://mapserver.gis.umn.edu/docs/howto/debian-odbc-mysql
There is another one:
http://mapserver.gis.umn.edu/docs/howto/ogrmysql
Hope that helps!
Regards, Till
> Hi!
> I would like use Database data to print point on my map.
> I searched on the web and found the method to that.
> So, I have the following code in a .ovf file:
>         MYSQL:gpvfr,user=gpvfr2,password=********,host=localhost,port=3306,tables=terrain
>         SELECT a.oaci, lat, 'long', nom FROM terrain t,airfields a WHERE a.oaci = t.oaci
>         EPSG:27582
>         wkbPoint
> And when I run ogrinfo on this file, I obtain:
> ERROR 1: MySQL connect failed for: gpvfr,user=gpvfr2,password=31p87qr2,host=localhost,port=3306,tables=terrain;airfields
> Access denied for user 'gpvfr2'@'localhost' (using password: YES)
> FAILURE:
> Unable to open datasource `var/www/html/ms/map_files/mysql.ovf' with the following drivers.
>   -> ESRI Shapefile
>   -> MapInfo File
>   -> UK .NTF
>   -> SDTS
>   -> TIGER
>   -> S57
>   -> DGN
>   -> VRT
>   -> REC
>   -> Memory
>   -> BNA
>   -> CSV
>   -> GML
>   -> GPX
>   -> KML
>   -> GeoJSON
>   -> GMT
>   -> SQLite
>   -> MySQL
>   -> AVCBin
> I'm sure of the connexion informations and MySql is installed on my system and GDAL library has been built with ogr option.
> Where is the problem?
> Thanks for your help and sorry for my English, I'm frenchy :)
> Sincerely yours
> Clement
> _________________________________________________________________
> Découvrez les profils Messenger de vos amis !
> http://home.services.spaces.live.com/_______________________________________________
> mapserver-users at lists.osgeo.org
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
