[mapserver-users] How to tile a large TIF image?
Paul Spencer
pspencer at DMSOLUTIONS.CA
Fri Apr 18 09:07:50 EDT 2008
Sounds like a problem with your gdal install - I'm running a mac also
and have no problems. I recommend going back to the kyngchaos site
and downloading the latest GDAL and installing it.
Cheers
Paul
On 18-Apr-08, at 9:02 AM, Stefan Schwarzer wrote:
> Thanks a lot for these details. That should be added to the existing
> documents!
> But unfortunately I still get a "Segmentation fault" message...
> Stef
>> Stefan,
>> I don't think you can specify 10'', you need something in pixels.
>> But the command is also probably not what you really need to do.
>> More likely, you should be doing the following:
>> gdal_translate -co "TILED=YES" gebco/bathymetry.tif gebco/
>> bathmetry_tiled.tif
>> This will create a single tif file that has an internal block size
>> of 256x256 - you can think of this as having broken your tif up
>> into 256x256 tiles but keeps them all within the same file. This
>> is equivalent to breaking the tif up into individual files,
>> creating a shapefile that has rectangles for each individual files'
>> extent, and using that as a tile index in mapserver.
>> Next, you want to do this:
>> gdaladdo gebco/bathymetry.tif 2 4 6 8 16
>> this will pre-compute smaller versions of the tif image called
>> overviews at 1/2, 1/4 1/6 1/8 and 1/16 of the original size of the
>> tif - this makes it much more efficient for gdal to return exactly
>> what mapserver is asking for at any given scale. Depending on the
>> range of scales that you need to display your raster image at, you
>> can add more overview levels (or take some away).
>> With this two commands, you can make your rasters much more
>> efficient for mapserver and probably avoid the need to split them
>> up into many files.
>> It does make the file somewhat larger. If you are working with
>> very large files ( > 4GB ) then you may run into some problems with
>> tiff and may need to investigate another format or a compressed
>> format like ECW or MrSID (both requiring commercial licenses I
>> believe).
>> There are also some built in compression schemes for tiffs in gdal
>> which you can apply when running gdal_translate (see http://www.gdal.org/frmt_gtiff.html
>> for creation options), for instance:
>> gdal_translate -co "TILED=YES" -co "COMPRESS=JPEG" -co
>> "JPEG_QUALITY=80" gebco/bathymetry.tif gebco/bathmetry_tiled.tif
>> would compress the tif using JPEG compression (lossy) set to 80%
>> (low compression, small loss).
>> Cheers
>> Paul
>> On 18-Apr-08, at 5:47 AM, Stefan Schwarzer wrote:
>>> Thanks for the info.
>>> Did it like this:
>>> Library/Frameworks/GDAL.framework/Versions/1.5/Programs/
>>> gdal_translate -outsize 10'' 10'' -co TILED=YES gebco/
>>> bathymetry.tif gebco/bathymetry_tiled.tif
>>> But get the message: "Segmentation fault"
>>> Anything that I did wrong? Or should do differently?
>>> Thanks for a hint,
>>> Stef
>>>> Hi,
>>>> Gdal_translate program has options for you:
>>>> c:\FWTools>gdal_translate
>>>> Usage: gdal_translate [--help-general]
>>>> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>>>> CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>>>> [-of format] [-b band] [-outsize xsize[%] ysize[%]]
>>>> [-scale [src_min src_max [dst_min dst_max]]]
>>>> [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
>>>> [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>>>> [-gcp pixel line easting northing [elevation]]*
>>>> [-mo "META-TAG=VALUE"]* [-quiet] [-sds]
>>>> [-co "NAME=VALUE"]*
>>>> src_dataset dst_dataset
>>>> By playing with -srcwin or possibly with -outsize and -projwin
>>>> you should be able to split your image as you wish. Read more from
>>>> http://gdal.org/gdal_translate.html
>>>> -Jukka Rahkonen-
>>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org
>>>> ] Puolesta Stefan Schwarzer
>>>> Lähetetty: 18. huhtikuuta 2008 12:05
>>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>>> Aihe: [mapserver-users] How to tile a large TIF image?
>>>> Hi there,
>>>> I would like to use instead of single large tif image smaller
>>>> tiles. Although I am well aware of mapserver's and gdal's
>>>> possibilities to create the shapes for it, I first need to
>>>> "split" the large tif into 20 or 50 or 100 tiles.
>>>> Can anyone give me a hint with what kind of software this is
>>>> possible?
>>>> There is an ArcGIS script, but it doesn't work on my machine ( http://arcscripts.esri.com/details.asp?dbid=13978
>>>> Thanks for any hints,
>>>> Stef
>>>> ____________________________________________________________________
>>>> Stefan Schwarzer
>>>> Lean Back and Relax - Enjoy some Nature Photography
>>>> http://photoblog.la-famille-schwarzer.de
>>>> Appetite for Global Data? UNEP GEO Data Portal:
>>>> http://geodata.grid.unep.ch
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://www.dmsolutions.ca/
Paul Spencer
