[mapserver-users] Displaying points & la
Michael Schulz
mschulz at webgis.de
Fri Apr 18 12:11:31 EDT 2008
Hi Clement,
please answer not directly to me, but to the mapserver list.
sorry i forgot you have to add the -o output option to shp2img:
Then it should save the image to the specified file. Still no points?
Michael
2008/4/18 Clemiou <clems_mars at hotmail.com>:
> Hi!
> I resolved the last error but now, I don't have error! Just this log and always no points & labels.
> [Fri Apr 18 16:58:43 2008].559339 msOGRFileOpen(mysql.ovf)...
> [Fri Apr 18 16:58:43 2008].569987 OGROPen(/usr/local/mapserver-5.0.2/../../../var/www/html/ms/map_files/mysql.ovf)
> [Fri Apr 18 16:58:51 2008].160106 msConnPoolRegister(AERO,mysql.ovf,0x8802e20)
> [Fri Apr 18 16:58:51 2008].332909 msOGRLayerClose(mysql.ovf).
> [Fri Apr 18 16:58:51 2008].332975 msOGRFileClose(/usr/local/mapserver-5.0.2/../../../var/www/html/ms/map_files/mysql.ovf,0).
> [Fri Apr 18 16:58:51 2008].332989 msConnPoolRelease(AERO,mysql.ovf,0x8802e20)
> [Fri Apr 18 16:58:51 2008].333003 msConnPoolClose(mysql.ovf,0x8802e20)
> [Fri Apr 18 16:58:51 2008].333276 msDrawMap(): Layer 1 (AERO), 7.953s
> [Fri Apr 18 16:58:51 2008].333330 msDrawMap(): Drawing Label Cache, 0.000s
> [Fri Apr 18 16:58:51 2008].333348 msDrawMap() total time: 7.976s
> GIF87a� � ������,� � ��ŋ���ڋ���H�扦�ʶ�
> ��L����
> ËçôºýŽÏë÷ü¾ÿ (8HXhx������� )9IYiy�������� *:JZjz������
> K[k{��������
> ,N^n~���� /?O_⎺ Ÿ¯¿Ïßïÿ0��� ]m}������
> ¼øñäË›? >½úõìÛ» ?�����ۿ扤��`� H◆ ˆ◆‚~
> .È◆ƒ▒„ NH▒… ^ˆ▒† ┼È▒‡ ␉ˆ"ŽH␉‰&žˆ␉Š*(R)È␉‹.␌Œ2ÎH␌ 6Þˆ␌Ž:îÈ␌ >␍ BI␍'F ‰␍'J.É␍"N> ␊"RNI␊•V^‰␊–Z┼É␊—^· °˜␉ŽI°™°ž‰°š┘(R)É°›┼¾ ±œ⎼ÎI± ┴Þ‰±ž≥îɱŸ·þ  ‚J¡† Š¢Š.Ê£Ž>
> ␋¤'NJ␋¥–^Š␋¦š┼Ê␋§ž·
> ┘¨¢ŽJ┘(c)¦žŠ┘ªª(R)Ê┘«(R)¾
> ┐¬²ÎJ┐¶ÞŠ┐(R)ºîÊ┐¯¾þ
> ┌°ÂK┌±Æ ‹þ┌²Ê.Ë┌³Î>
> └´ÒNK└µÖ^‹└¶Ú┼Ë└·Þ·
> ┼¸âŽK┼¹æž‹┼ºê(R)Ë┼»î¾
> ⎺¼òÎK⎺½öÞ‹⎺¾úîË⎺¿þþ
> ⎻À Lp� �p
> [Fri Apr 18 16:58:51 2008].616500 msFreeMap(): freeing map at 0x87297f8.
> Thanks for your help
> Clement
> > Date: Fri, 18 Apr 2008 15:45:17 +0200
> > From: mschulz at webgis.de
> > To: clems_mars at hotmail.com; mapserver-users at lists.osgeo.org
> > Subject: Re: [mapserver-users] Displaying points & lab
> > Hi Clement,
> > please leave the thread also on the list...
> > Ok, that is not the real debug output, merely the log. Did you try it
> > from the command line with shp2img:
> > shp2img -m aero.map -l AERO -all_debug 5
> > this should print some debug information to stdout. Are you using
> > mapserver 5? Then you can set a special error log for each mapfile,
> > with the directive CONFIG "MS_ERRORFILE" "/path/to/mserror.log" at the
> > map level.
> > Cheers, Michael
> > 2008/4/18 Clemiou :
> >> Hi
> >> The one thing that I can see in the mapserver log is:
> >> Fri Apr 18 15:18:51 2008,18284,127.0.0.1,MS,3,1.241143 46.540217 1.445917 46.744991,-1.000000 -1.000000,FRANCE ,normal execution
> >> ^^ Very funny isn't it?
> >> Clement
> >> > Date: Fri, 18 Apr 2008 15:03:59 +0200
> >> > Subject: Re: [mapserver-users] Displaying points & labe
> >> > Hi,
> >> > could you have a look at the debug output? Turn debugging on with
> >> > DEBUG on on the map and on the layer level, then you should get debug
> >> > output, either to your configured mapserver log or the webserver
> >> > (error) log. Another way woudl be to use shp2img.
> >> > Cheers, Michael
> >> > 2008/4/18 Clemiou :
> >> >> Hi,
> >> >> I have modifief my layer for just have the points, as you can see:
> >> >> # Le layer des aérodromes . #
> >> >> LAYER
> >> >> NAME "AERO"
> >> >> TYPE POINT
> >> >> STATUS ON
> >> >> PROJECTION
> >> >> "init=epsg:27582"
> >> >> END
> >> >> TEMPLATE "ttt_query.html"
> >> >> CONNECTIONTYPE OGR
> >> >> CONNECTION "mysql.ovf"
> >> >> #TOLERANCE 5
> >> >> #TYPE ANNOTATION
> >> >> #LABELITEM "nom"
> >> >> DATA "my_layer"
> >> >> CLASS
> >> >> NAME "my_class"
> >> >> #LABEL
> >> >> # ANGLE auto
> >> >> #TYPE TRUETYPE
> >> >> #ANTIALIAS TRUE
> >> >> #MINFEATURESIZE 100
> >> >> #COLOR 255 255 255
> >> >> #OUTLINECOLOR 255 0 0
> >> >> #SIZE 20
> >> >> #FONT "arial"
> >> >> #FORCE TRUE
> >> >> #END # Fin LABEL AERO
> >> >> STYLE
> >> >> SYMBOL 'circle'
> >> >> SIZE 15
> >> >> COLOR 0 255 0
> >> >> END # Fin du STYLE AERO
> >> >> END # Fin de CLASS AERO
> >> >> END # Fin du LAYER AERO
> >> >> But it doesn't work.
> >> >> Thakns for your answer
> >> >> Clement
> >> >>> Date: Fri, 18 Apr 2008 14:51:44 +0200
> >> >>> Subject: Re: [mapserver-users] Displaying points & label
> >> >>> CC: mapserver-users at lists.osgeo.org
> >> >>> Hi,
> >> >>> you are using a layer of type annotation. This type of layer usually
> >> >>> does not display the actual point symbol, it only renders the label at
> >> >>> that position. Thus you could try to use type point, to really draw
> >> >>> the points and the labels... I just realized that you have two TYPE
> >> >>> declarations in your layer: point and annotation. That could also be a
> >> >>> problem ;-)
> >> >>> Cheers, Michael
> >> >>> 2008/4/18 Clemiou :
> >> >>>> Hi!
> >> >>>> I'd like displaying points and labels. My points are on MySql database and I use them with OGR.
> >> >>>> The connexion is OK and I think my mapfile too.
> >> >>>> But I don't see the points and the labels.
> >> >>>> My codes can be see on: http://www.forumsig.org/showthread.php?p=144085#post144085
> >> >>>> I hope find someone to help me.
> >> >>>> Have a nice day.
> >> >>>> Clement
> >> >>>> PS: Excuse me for my English, I'm a frenchy!
> >> >>>> _________________________________________________________________
> >> >>>> Créez votre disque dur virtuel Windows Live SkyDrive, 5Go de stockage gratuit !
> >> >>>> http://www.windowslive.fr/skydrive/_______________________________________________
> >> >>>> mapserver-users mailing list
> >> >>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> >>> Michael Schulz
> >> >>> in medias res
> >> >>> Gesellschaft für Informationstechnologie mbH
> >> >>> In den Weihermatten 66
> >> >>> 79108 Freiburg
> >> >>> Tel +49 (0)761 556959-5
> >> >>> Fax +49 (0)761 556959-6
> >> >>> http://www.webgis.de / http://www.zopecms.de
> >> > Michael Schulz
> >> > in medias res
> >> > 79108 Freiburg
> > Michael Schulz
> > in medias res
> > 79108 Freiburg
Michael Schulz
in medias res
79108 Freiburg
