[mapserver-users] Displaying points & label
Clemiou
clems_mars at hotmail.com
Fri Apr 18 17:29:04 EDT 2008
Now I have the good projections I think but I don't see the points.I have:
WGS84 for my map.EPSG:27582 for my map Layer
WGS84 for my label layer.
What do you think about that? Is it Ok with my datas (WGS84 for database datas and Lambert II for my Map).
Thanks for you answer
Clement
> Date: Fri, 18 Apr 2008 18:25:01 +0200> From: mschulz at webgis.de> To: mapserver-users at lists.osgeo.org> Subject: Re: [mapserver-users] Displaying points & label> > Hi,> > in your ovf as well as in the layer definition you claim your data to> be in EPSG:27582, if it is actually in epsg:4326 then it should say so> in both places. The layer projection defines in which system your data> is in, the map projection defines in what system your image is> rendered (and your data projected to on the fly if necessary).> > Cheers, Michael> > 2008/4/18 Clemiou <clems_mars at hotmail.com>:> >> > Hi!> >> > Still no points!> > But I found perhaps something...> > My datas are in WGS84 format and my map in Lambert II.> > So, in my mapfile, my Map object has WGS84 projection, the layer of my Map, Lambert II format and the layer of my points the WGS84 format.> > But still no points.> > I don't know why. ^^> >> > Thanks for your help.> > Clement> > _________________________________________________________________> > Découvrez les profils Messenger de vos amis !> > http://home.services.spaces.live.com/_______________________________________________> >> >> > mapserver-users mailing list> > mapserver-users at lists.osgeo.org> > http://lists.osgeo.org/mailman/listinfo/mapserver-users> >> > > > -- > -----------------------------------------------------------> Michael Schulz> mschulz at webgis.de> > in medias res> Gesellschaft für Informationstechnologie mbH> > In den Weihermatten 66> 79108 Freiburg> > Tel +49 (0)761 556959-5> Fax +49 (0)761 556959-6> > http://www.webgis.de / http://www.zopecms.de> -----------------------------------------------------------> _______________________________________________> mapserver-users mailing list> mapserver-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Créez votre disque dur virtuel Windows Live SkyDrive, 5Go de stockage gratuit !
http://www.windowslive.fr/skydrive/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080418/bd8d8ac5/attachment-0001.html
