[mapserver-users] Oracle+WMS: GetCapabilities issueUID 1559)
bartvde at osgis.nl
bartvde at osgis.nl
Wed Apr 23 08:21:32 EDT 2008
Add ows_extent for your LAYERS METADATA.
Mapserver is trying to calculate the bounds of your layers, and that's a
very slow function in Oracle (and in other spatial DBMS-s as well IIRC).
Best regards,
Bart
On Wed, 23 Apr 2008 14:13:57 +0200, "Diego Guidi" <diegoguidi at gmail.com>
wrote:
> I'm using the last ms4w package and I'm experiencing an issue with
> GetCapabilities request... in one word: is terribly slow :(
> I've created a map file from a bunch of layers in SDE and all works
> well, then I've moved the same data to Oracle Spatial, changed
> configuration of the map file and now the problem appears.
> I want to specify this: only getcapabilities is terribly slow (10
> minutes for 10 layers), getmap requests and getfeatureinfo requests
> are fast, actually much faster that with SDE...
> anyone has experienced this issue?
> mapserver-users at lists.osgeo.org
