[MAPSERVER-USERS] Postgis and Mapserver
Hans Castorp
hanscastorp76 at yahoo.es
Fri Apr 25 06:56:56 EDT 2008
Hi Ritesh,
I have no errors in my log file. Additionally mo images are generated with the required simbology.
Thanks in advance.
-----Mensaje original-----
De: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Ritesh Ambastha Enviado el: viernes, 25 de abril de 2008 10:12
Para: mapserver-users at lists.osgeo.org
Asunto: Re: [MAPSERVER-USERS] Postgis and Mapserver
Hey Hans,
Please check the mapserver log for the error(s).
Also, do check the 'tmp' directory where map images are generated.
Regards,
Ritesh Ambastha
Hans Castorp wrote:
> Hi to all,
> In the past days I have been answering some questions about it but, by
> now, I haven’t achieved my goal. I will try to explain what I have and
> what I want (need, in fact):
> I’m displaying some cartography: lines and polygons from shape files
> and points from a Postgis table (without filtering).
> At the same time, I have a form to query the postgis table applying
> some filters. I am making these queries using PHP and SQL in the usual
> way. I don’t use mapscript queryByAttibutes, because SQL queries are
> more flexible and powerful (I think). Due to these facts what I have
> is: on one side, a map showing all the points (with no filter) and, on
> the other side, a filtered list of these same points.
> What I’m looking to do is:
> - Zoom to all my selection, changing simbology in order to show
> some points with the default simbology (map file) and others (the
> result of my selection) with a special simbology.
> - Zoom to one chosen point in my selection. By now, I’m doing it
> using zoomToExtents, passing as parameters x and y of the point
> (retrieved in the sql query). This works fine but I need to change the
> simbology of the selected point in order to make it clearly visible between the others.
> What I’m trying in order to change simbology for selected points is
> something like this:
> $oMap = ms_newMapObj($szMapFile);
> $oLayer = $oMap->getLayerByName("EMPRESAS");
> $oClass = $oLayer->getClass(0);
> $oEstilo = $oClass->getStyle(0);
> $oLayer->setFilter($sql);
> $oEstilo->set("symbolname", "MARKER_EMPRESA_ALT");
> But I have no results (at least no errors, too J)
> Some help will be welcomed.
> Thanks in advance to everyone.
> Hans Castorp
> __________________________________________________
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
> Regístrate ya - http://correo.yahoo.es
View this message in context: http://www.nabble.com/Postgis-and-Mapserver-tp16740842p16892667.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.4/1396 - Release Date: 24/04/2008 18:32
No virus found in this outgoing message.
Checked by AVG.
Enviado desde Correo Yahoo! La bandeja de entrada más inteligente.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080425/58329a01/attachment.html
