[mapserver-users] Large scale PDF output on Windows
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Apr 28 09:50:54 EDT 2008
Brent,
> If there's enough interest, I'd be willing to contribute the code
> changes he made if there's a Mapserver developer/committer willing to
> review, upgrade them to v5,and test (and it may require an RFC as there
> was a map file addition to OUTPUTFORMAT/FORMATOPTIONS, I think).
I would be willing to review/apply patches on this. I have created a bug
on this http://trac.osgeo.org/mapserver/ticket/2596.
Best Regards
> Brent Fraser
> Kristian Thy wrote:
>> On Thu, Apr 24, Flavio Hendry wrote:
>>> Discussed the issue a while ago with Frank Warmerdam. He had less
>>> problems on a LINUX System running on a 64bit machine (he supposes it
>>> could go as high as 25'000 pixels). On Windows 32 it bangs at around
>>> 10'000 to 14'000 pixels depending on content. Did not try on Windows 64.
>> Thanks to advice from the list, I now have huge orthophoto pdfs. But now
>> I have another problem - using png output, I get nice 24 bit images, but
>> my pdf output is dithered 8 bit. The relevant part of my map file:
>> IMAGETYPE png24
>> OUTPUTFORMAT
>> NAME png
>> MIMETYPE "image/png"
>> DRIVER AGG/PNG
>> EXTENSION png
>> IMAGEMODE RGB
>> TRANSPARENT FALSE
>> END #outputformat
>> OUTPUTFORMAT
>> NAME pdf
>> MIMETYPE "application/x-pdf"
>> DRIVER pdf
>> EXTENSION pdf
>> IMAGEMODE RGB
>> FORMATOPTION "OUTPUT_TYPE=RASTER"
>> TRANSPARENT FALSE
>> END #outputformat
>> Removing the FORMATOPTION makes no difference.
>> http://quovadis.dk/dl/ortho.png
>> http://quovadis.dk/dl/ortho.pdf
>> The commandline incantation used to produce the images:
>> $ shp2img -m ddo.map -o ortho.pdf -s 1654 1169 -l DDO -e 659000
>> 6058000 663200 6060970 -i pdf
>> Does the pdf driver support 24 bit at all? Can I do 24 bit pngs and
>> assemble the pdfs by hand?
>> \\kristian
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
