[MAPSERVER-USERS] Mapserv problems on Fedora
Philippe Kruschitz
p_kruschitz at hotmail.com
Tue Apr 29 06:48:52 EDT 2008
Hi Steven,
Thanks for the hint. I'm glad it worked for you, although I doubt this has
anything to do with AGG.
Usually, trying to access non-existent mapfiles throws a LoadMap error:
msLoadMap(): Unable to access file. (/home/pk/gis/no.map)
Trying with non-existent and working mapfiles (using GD rendering) always
gets me the same error:
[http://localhost/cgi-bin/mapserv?map=no.map]
msEvalRegex(): Regular expression error. String (no.map) failed expression
test.
[http://localhost/cgi-bin/mapserv?map=/home/pk/gis/no.map]
msEvalRegex(): Regular expression error. String (/home/pk/gis/no.map) failed
expression test.
[http://localhost/cgi-bin/mapserv?map=/home/pk/gis/test.map]
msEvalRegex(): Regular expression error. String (/home/pk/gis/test.map)
failed expression test.
To be sure, I recompiled Mapserver without agg support, getting the same
result.
I'm slowly considering switching to an Ubuntu server, as I tried almost
everything I could.
By the way, how did you find out about your bug?
Best regards,
Philippe
Stephen Woodbridge wrote:
> Philippe,
> My regex crash was because of a bug in mapserver
> http://trac.osgeo.org/mapserver/ticket/2577#comment:8
> which has been fixed now in svn. It was specifically related to a crash
> cause when AGG FORMATOPTION PALETTE=<file> could not open <file>.
> Hope this helps,
> -Steve W
> Philippe Kruschitz wrote:
>>> You --must-- compile and install the last version of
>>> gd, the gd version on RHEL 5 and 5.1 is broken, also
>>> on centos and fedora core 8.
>>> Be sure to replace the old gd version on /usr/lib,
>>> also check the simlinks on /usr/lib, then run ldconfig
>>> as root.
>>> If you use mapserver with phpmapscript install php-gd
>>> with yum.
>>> Hope this helps.
>>> Saludos.
>>> Nahum Castro
>>> Leon, Guanajuato, Mexico
>>> http://www.leon-linux.com
>>> e-mail: pedro1_72 [en] yahoo [punto] com
>> I did pretty much everything you said before compiling mapserver (i
>> didn't
>> have mapscript, though).
>> I tried to to change the malloc value, as frank warmerdam suggested, with
>> exactly the same result as stephen woodbridge: the crash is fixed, but
>> the
>> regular expression systematically fails.....
>> Anyone has an idea? Did Stephen fixed it?
>> Regards,
>> Phil
>> Quote S. Woodbridge:
>> Hi Frank,
>> Adding more to to the malloc fixed the crash, but the regex is failing
>> :( and should be ok:
>> Breakpoint 1, msEvalRegex (e=0x4e9873 "\\.map$",
>> s=0x7232a0 "/u/data/maps/google-agg.map") at mapfile.c:79
>> 89 if(ms_regexec(&re, s, 0, NULL, 0) != 0) { /* no match */
>> (gdb) p ms_regexec(&re, s, 0, 0, 0)
>> $1 = 1
>> (gdb) c
>> Continuing.
>> Content-type: text/html
>> <HTML>
>> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
>> <!-- MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7
>> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
>> <BODY BGCOLOR="#FFFFFF">
>> (/u/data/maps/google-agg.map) failed expression test.
>> </BODY></HTML>
>> Program exited normally.
>> This should NOT be happening. Arrrgh!
>> Anyone else using fc8 on a x86_84 box?
>> -Steve
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Mapserv--problems-on-Fedora-tp16688820p16957618.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
