[MAPSERVER-USERS] mapserver does not show oracle layer
bartvde at osgis.nl
bartvde at osgis.nl
Wed Aug 6 05:51:51 EDT 2008
What do you get if you use shp2img with debug info?
shp2img -all_debug 10
Best regards,
Bart
> Hi,
> i´m having troubles shwoing a oracle layer in mapserver.
> in open layers i´ve:
> map = new OpenLayers.Map( 'map' ,
> scales: [ 4000000,3000000,2000000,1000000, 500000,200000,
> 100000, 50000,20000,10000 ],
> maxExtent: new OpenLayers.Bounds(-18,34,4,45),
> numZoomLevels: 10
> var basemap = new OpenLayers.Layer.WMS.Untiled( "MS 4.10",
> "http://172.18.210.67:8080/cgi-bin/mapserv.exe?",
> map: '/ms4w/apps/wmssrvrefer/config.map',
> layers: 'border', format: 'png', 'transparent': 'on'},
> { projection:"EPSG:4326" } );
> map.addLayers([basemap]);
> map.setCenter(new OpenLayers.LonLat(-8, 39.5), 0);
> In mapfile:
> EXTENT -9 36 -6 42
> projection
> "init=epsg:4326"
> end
> web
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> metadata
> wms_title "test"
> wms_srs "EPSG:4326"
> end
> end
> ## this show the layer !
> layer
> name major_roads_small_4
> group border
> type line
> projection
> "init=epsg:4326"
> end
> status on
> data railways.shp
> class
> style
> color 0 0 0
> width 1
> antialias true
> end
> end
> end
> this layer does not show !!
> layer
> name road_a
> group border
> type line
> projection
> "init=epsg:4326"
> end
> connectiontype oraclespatial
> connection "uui/pwdmydb"
> data "geom_73 from caop_regiao using srid 4326"
> class
> style
> color 185 175 155
> width 3
> antialias true
> end
> end
> end
> I test with shp2img and it shows the shapelayer, but not the oracle layer.
> http://www.nabble.com/file/p18847632/test.png
> What´s wrong ?
> http://www.nabble.com/mapserver-does-not-show-oracle-layer-tp18847632p18847632.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
