[MAPSERVER-USERS] Road Lines with AGG
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Wed Aug 6 14:33:59 EDT 2008
Here is what I have used for PNG in the OUTPUFORMAT:
# Image Output Definition
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
EXTENSION "png"
IMAGEMODE RGB
FORMATOPTION INTERLACE=ON
FORMATOPTION QUALITY=90
END
This has worked for me. Also, here is an example of a road layer:
# Layer: US Small Scale Secondary Highways and Major Roads
LAYER
NAME "US Small Scale Secondary Highways and Major Roads"
GROUP "Secondary Highways"
STATUS ON
TILEINDEX "us_streets/indexes/hwy_merge_index"
TILEITEM "location"
TYPE LINE
SIZEUNITS PIXELS
CLASSITEM "NCLASS"
TEMPLATE "../mapserver/cgi-query-templates/ushwy.html"
HEADER "../mapserver/cgi-query-templates/usshwy_mroad-header.html"
FOOTER "../mapserver/cgi-query-templates/footer.html"
TOLERANCE 5
TOLERANCEUNITS PIXELS
# Class: US Small Scale Secondary Highways and Major Roads, Scale 10
CLASS
#NAME "County Highways"
EXPRESSION "A30"
MINSCALE 1000000
MAXSCALE 3000000
STYLE
SYMBOL "circle"
COLOR 223 214 113
SIZE 1
END
END
# Class: US Small Scale Secondary Highways and Major Roads, Scale 9
CLASS
EXPRESSION "A30"
MINSCALE 500000
MAXSCALE 1000000
STYLE
SYMBOL "circle"
COLOR 192 192 91
SIZE 3
END
STYLE
SYMBOL "circle"
COLOR 252 252 151
SIZE 1
END
END
END
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Ritesh Ambastha
> Sent: Wednesday, August 06, 2008 11:01 AM
> To: mapserver-users at lists.osgeo.org
> Subject: RE: [MAPSERVER-USERS] Road Lines with AGG
> Still looking for a solution :(
> -Ritesh
> Nolte, Tim wrote:
> > When you are using AGG for your output do not use antialias
> true on your
> > layers.
> > - Tim
> > iPCS Wireless, Inc.
> > Kentwood, MI 49512
> > PCS: 616-706-2438
> > Fax: 616-554-6484
> >> Ritesh Ambastha
> >> Sent: Tuesday, August 05, 2008 6:53 AM
> >> Subject: [MAPSERVER-USERS] Road Lines with AGG
> >> http://www.nabble.com/file/p18828729/road.png
> >> In the map file, I have defined the imagetype and outputformat as:
> >> IMAGETYPE AGG
> >> OUTPUTFORMAT
> >> NAME 'AGG'
> >> DRIVER AGG/PNG
> >> IMAGEMODE RGB
> >> END
> >> My line layers are written with antialias as true.
> >> How can I correct the lines with more smoothness while
> >> keeping the same
> >> sharpness?
> >> Thanks,
> >> Ritesh Ambastha
> >> View this message in context:
> >> http://www.nabble.com/Road-Lines-with-AGG-tp18828729p18828729.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://www.nabble.com/Road-Lines-with-AGG-tp18828729p18853113.html
