[mapserver-users] ogrinfo failure.
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Aug 7 15:11:02 EDT 2008
Open up a dos prompt and first run ms4w\setenv.bat, after that you can
use ogrinfo.
Best regards,
Bart
Νίκος Παπαδάκης wrote:
> Hi list.
> I have a problem running ogrinfo.exe.
> When i press enter i get the following message:
> "This application has failed to start because gdal15.dll was not
> found.Re-installing the application may fix this problem".
> Well,i re-installed ms4w but the problem remains.
> Does anyone know where the error might be?
> Thank you in advance...!
> mapserver-users at lists.osgeo.org
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
