[mapserver-users] MAXFEATURES or FEATURE_COUNT w/ WMS call, output
text/html
Daniel Morissette
dmorissette at mapgears.com
Mon Aug 11 14:09:31 EDT 2008
Josh Marcus wrote:
> Hey there,
> I was wondering if I could get some help or advice on using the
> FEATURE_COUNT (or MAXFEATURES) parameter with a WMS call. I'm using
> Mapserver 4.99.
> My output type is text/html, which I'm using to generate JSON. The data
> layer is a postgresql/postgis database. In general, it's working fine
> -- except that I want to limit the response to a maximum number of
> features. Passing in a FEATURE_COUNT cgi parameter seems to have no
> effect at all. Interestingly, passing in MAXFEATURES (with any value)
> limits the output to a single feature.
FEATURE_COUNT had no effect with INFO_FORMAT=text/html in 5.0 and older.
This was fixed in v5.2, so you'll have to upgrade to 5.2 or patch your
local install. All the details in ticket #1686:
http://trac.osgeo.org/mapserver/ticket/1686
Daniel
Daniel Morissette
http://www.mapgears.com/
