Fwd: [MAPSERVER-USERS] Problems calculating MAXSCALES
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 13 11:51:01 EDT 2008
Rob,
Please post the new ticket number so we can follow this issue.
Thanks,
-Steve W
Daniel Morissette wrote:
> Glad to hear that Trac prevents reopening closed tickets by default.
> This is not a bad thing since that ticket was closed in a previous
> release and reopening tickets usually leads to confusion.
> I'd suggest you open a new ticket and refer to the original one that you
> were trying to reopen.
> Daniel
> Rob wrote:
>> Sorry - didnt reply to whole list
>> ---------- Forwarded message ----------
>> From: Rob <gis at vanbooth.com>
>> Date: 2008/8/13
>> Subject: Re: [MAPSERVER-USERS] Problems calculating MAXSCALES
>> To: Tamas Szekeres <szekerest at gmail.com>
>> I was unable to reopen the ticket with comments - "TICKET_APPEND
>> privileges are required to perform this operation"
>> If someone else could reopen on my behalf, this is what I wrote for
>> the comments -
>> I've recently updated from 4.8.6 to 5.0.2 and fallen foul of this
>> defect, where layers are not visible when I would expect them to be.
>> I'm in OSGB Projection (epsg:27700) but I didn't include this
>> information in my sample mapfiles, in case it was a projection related
>> issue. My implementation uses mapscript rather than the cgi mapserv
>> process, but I have been testing using shp2img.
>> 4.8.3 Mapfile
>> MAP
>> EXTENT 200000 200000 266145 266145
>> IMAGECOLOR 255 255 255
>> IMAGETYPE png
>> RESOLUTION 96.000000
>> SIZE 500 500
>> STATUS ON
>> TRANSPARENT TRUE
>> UNITS METERS
>> NAME "Base"
>> IMAGEQUALITY 75
>> LEGEND
>> KEYSIZE 20 10
>> KEYSPACING 5 5
>> LABEL
>> SIZE MEDIUM
>> TYPE BITMAP
>> BUFFER 0
>> COLOR 0 0 0
>> FORCE FALSE
>> MINDISTANCE -1
>> MINFEATURESIZE -1
>> OFFSET 0 0
>> PARTIALS TRUE
>> END
>> POSITION LL
>> STATUS OFF
>> END
>> WEB
>> IMAGEPATH "c:\tmp\"
>> IMAGEURL "/"
>> QUERYFORMAT text/html
>> LEGENDFORMAT text/html
>> BROWSEFORMAT text/html
>> END
>> LAYER
>> MAXSCALE 500000
>> MINSCALE 0
>> NAME "Land"
>> STATUS ON
>> TRANSPARENCY 100
>> TYPE RASTER
>> UNITS METERS
>> DATA "C:\Documents and Settings\Administrator\Desktop\gb\gbpng.tif"
>> END
>> END
>> 5.0.2 Mapfile
>> MAP
>> IMAGETYPE png
>> SIZE 500 500
>> STATUS ON
>> TRANSPARENT TRUE
>> UNITS METERS
>> NAME "Base"
>> OUTPUTFORMAT
>> NAME "png"
>> MIMETYPE "image/png"
>> DRIVER "GD/PNG"
>> EXTENSION "png"
>> IMAGEMODE "PC256"
>> TRANSPARENT TRUE
>> END
>> PROJECTION
>> "init=epsg:27700"
>> END
>> LEGEND
>> KEYSIZE 20 10
>> KEYSPACING 5 5
>> LABEL
>> SIZE MEDIUM
>> TYPE BITMAP
>> BUFFER 0
>> COLOR 0 0 0
>> FORCE FALSE
>> MINDISTANCE -1
>> MINFEATURESIZE -1
>> OFFSET 0 0
>> PARTIALS TRUE
>> END
>> POSITION LL
>> STATUS OFF
>> END
>> WEB
>> IMAGEPATH "c:\tmp\"
>> IMAGEURL "/"
>> END
>> LAYER
>> DEBUG 5
>> MAXSCALEDENOM 500000
>> MINSCALEDENOM 0
>> NAME "Land"
>> STATUS ON
>> TRANSPARENCY 100
>> TYPE RASTER
>> UNITS METERS
>> END
>> END
>> GBPNG.TFW
>> 333.333333333
>> 0.000
>> 0.000
>> -333.333333333
>> 166.66666666
>> 649833.33333333
>> Any 1000x1000 image should work.
>> Running shp2img against 4.8.3 will produce a valid image. Running
>> shp2img against 5.0.2 does not.
>> Code is currently
>> center_y = (extent.miny+extent.maxy)/2.0;
>> md = (width-1)/(resolution*msInchesPerUnit(units, center_y)); /*
>> remember, we use a pixel-center to pixel-center extent, hence the
>> width-1 */
>> gd = extent.maxx - extent.minx;
>> *scale = gd/md;
>> For the extents in the mapfiles, this gives a scale of 500997
>> Previously, using (width) instead of (width-1), we would have had 499993
>> My desktop GIS product seems to agree with the calculation to result
>> in 499993, judging by the bbox it requests when zooming to 1:500,000
>> Full mapserver-users conversation is here -
>> http://www.nabble.com/Problems-calculating-MAXSCALES-td18926188.html
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
