[mapserver-users] libssl.so.6 error
Steve Smith
ssteve52 at yahoo.com
Thu Aug 14 23:16:48 EDT 2008
Paul,
Luigi Castro Cardeles, suggested I make a symbolic link from libssl.so to libssl.so.6.
I did that and it did not look like it worked, but after taking a closer look it had.
However, I was getting a similar error message for libcrypto.so.6, so I did that same
thing. Now I am getting a memory error for glibc:
[Thu Aug 14 23:00:54 2008] [error] [client 71.120.222.68] *** glibc detected *** /var/www/cgi-bin/mapserv: malloc(): memory corruption: 0x0000000000b4c3d0 ***, r
There is no option for ssl in the configure file. I do see links to it in my make out put.
However, I have not found reference to it in mapserver documentation. Do you know
if it is required? If I am having this problem it must be.
Jim
--- On Thu, 8/14/08, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
Subject: Re: [mapserver-users] libssl.so.6 error
To: ssteve52 at yahoo.com
Cc: mapserver-users at lists.osgeo.org
Date: Thursday, August 14, 2008, 11:46 PM
I'm thinking: recompile. If your old compile had a dependency on an
old library and your upgrade removed it... recompile so it depends on
your new libraries.
P.
On Thu, Aug 14, 2008 at 11:01 AM, Steve Smith <ssteve52 at yahoo.com> wrote:
> I am running mapserver 5.2, on a AMD 64 bit machine. I just upgraded from
> fedora
> core 8 to fedora core 9. After upgrading I began getting an error telling
me
> that
> libssl.so.6 does not exist. Fedora core 9 uses openssl-0.98g-9.fc9.x86_64
> and 686,
> which have a slew of important dependences. If I attempt to install older
> versions,
> such as openssl-098g-6, I am told that it conflicts with the current
> versions. How do
> I get mapserver to work with the current version of openssl?
> Thanks
> Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080814/22f47c04/attachment.html
