[mapserver-users] attach text to displayed features thatare
comingfrom postgis
Fawcett, David
David.Fawcett at state.mn.us
Mon Aug 18 15:07:04 EDT 2008
To be able to use a label, you will likely also have to modify your
select statement to include the columns that you want to use in labels
or expressions.
Try something like:
DATA "the_geom from (select myLabelColumn, the_geom from myTable) as foo
using
unique gid using SRID=4326"
Of course, you will want to make sure that you are specifying the actual
names of your unique id column and your SRID.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Steve Lime
Sent: Monday, August 18, 2008 1:31 PM
To: John Mitchell; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] attach text to displayed features thatare
comingfrom postgis
Check out the LABELITEM property for a layer. You'll also need to define
a LABEL for your class.
Steve
>>> On 8/18/2008 at 11:17 AM, in message
<fa2ac0580808180917h484b2524h58141eb88f6480a8 at mail.gmail.com>, "John
Mitchell" <mitchelljj98 at gmail.com> wrote:
> Hi,
> I would like to be able to attach text to displayed features that are
> coming from postgis. Currently I am just displaying points (layer
> displayed below) as an ellipse from postgis, but I would like to have
> text on top of each ellipse based on the contents of a field uniquely
> associated to each point.
> John
> LAYER
> # name of layer
> NAME "gv:tasmania_cities"
> GROUP "Collaboration"
> # what type of data is this?
> TYPE POINT
> # always returned with interface
> STATUS ON
> TRANSPARENCY 100
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres dbname=gvdb host=localhost port=5432
> password=password1117"
> DATA "the_geom from tasmania_cities"
> CLASS
> STYLE
> symbol "dot"
> SIZE 8
> COLOR 0 0 0
> END
> END
> END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
