[mapserver-users] build mapserver 5.2.0 with proj 4.6.0
Jacolin Yves yjacolin at free.fr
Tue Aug 19 05:36:45 EDT 2008
Hi Guillaume,
This is a fresh system install from a "virtual private server" under OpenVZ, I
tried to remove all packetage with apt-get remove, and nothing is removed ;)
Furthermore I setup the option --with-proj which link to /usr/local/lib where
libproj is installed (by myself).
I built all main dependance (proj, gdal, geos, libecw and agg).
It seems that configure script test pj_transform in proj and if this is not
present, think it is an old proj release. I ma going to check in the proj ML
to know more about this.
Regards,
Y.
Le Tuesday 19 August 2008 11:31:36 Guillaume Sueur, vous avez écrit :
> make sure you don't have any pre-installed Proj lib which would get
> linked during the ./configure
> Jacolin Yves a écrit :
> > Hello,
> > I am trying  to build mapserver 5.2.0 with proj-4.6.0. The ./configure
> > script tells me : "configure: error: This version of PROJ is too old.
> > PROJ4.4.2 or later is required." , here is the configure comande line:
> > ./configure
> > 	--with-postgis
> > 	--with-wmsclient --with-wfsclient
> > 	--with-geos
> > 	--with-proj=/usr/local/
> > 	--with-gdal --with-ogr
> > 	--with-freetype=/usr/bin/freetype-config --with-eppl
> > --with-xpm=/usr/X11R6/lib/ --with-gd=/usr/
> > --with-agg=/mnt/data/compil/agg-2.5/
> > 	--with-curl-config=/usr/bin/curl-config
> > 	--with-tiff --with-xml2-config=/usr/bin/xml2-config
> > Do you know how to resolv this?
> > Thanks
> > Y.
Yves Jacolin
http://softlibre.gloobe.org
