[MAPSERVER-USERS] fseek dbf error while importing shapefile in postgres
Gregor Mosheh gregor at hostgis.com
Tue Aug 19 10:59:19 EDT 2008
Ritesh Ambastha wrote:
> fseek(-1035313584) failed on DBF file.
> What can be the problem? What should be checked in the DBF for these kind of
> errors?
Are you positive that the DBF was uploaded correctly? The first thing I
would suspect is that I FTPd it in ASCII mode, or only got half of the
file uploaded. Check the DBF and make sure it's the right size and
md5sum, is my advice.
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
