Res: [mapserver-users] Change a class name by url
Jefferson Bauer
jepibr at yahoo.com.br
Tue Aug 19 12:09:24 EDT 2008
Thaks for your reply
Jeff.
I've used the migration
guide to change the way i modify variables by URL, like setting
templates in WEB or LEGEND, adding POINTS in a FEATURE, etc.
With that, my
application works fine. But in some cases i need to modify the name
of a class adding a number or a new text and this is the problem. In
the older version it's quite simple as i wrote, but now i can't do in
this new way and the error message doesn't explain too much...
Did you try to do this
class name change? Do you know another way to this?
Jefferson Bauer
----- Mensagem original ----
De: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Para: mapserver-users at lists.osgeo.org
Enviadas: Terça-feira, 19 de Agosto de 2008 2:10:45
Assunto: Re: [mapserver-users] Change a class name by url
hmm, u might also refer to the 5.0 migration guide, in case it helps
you:
http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MIGRATION_GUIDE.TXT
I have also seen a variation of this error:
http://lists.osgeo.org/pipermail/mapserver-users/2008-May/055877.html
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
Jefferson Bauer wrote:
> Hello
> I was upgrading my
> mapserver from 4.6 to 5.2 (using MS4W v2.2.8 ) and everything was ok
> utntil i run a function that change the name of a CLASS by URL. My
> mapfile have a layer like:
> LAYER
> NAME municipio
> CLASS
> NAME
> "sedes"
> END
> END
> I'm using mapserver as
> CGI and to do the change in 4.6 i use this:
> &map_municipio_sedes_name=newname
> Now in 5.2 i read this
> article:
> http://mapserver.gis.umn.edu/docs/reference/cgi/referencemanual-all-pages
> So, the new way to do
> what i want must be something
> like:
> &map_layer[municipio]_class[sedes]_name=newname
> or
> &map_layer[0]_class[0]_name=newname
> But it's not working... I receive this error:
> loadClass(): Unknown identifier. Parsing error near (name):(line 1)
> Am i doing something
> wrong or this change is not allowed anymore?
> Thanks,
> Jefferson Bauer
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Novos endereços, o Yahoo! que você conhece. Crie um email novo com a sua cara @ymail.com ou @rocketmail.com.
http://br.new.mail.yahoo.com/addresses
