[mapserver-users] date format?
Sacha Black
sacha.black at gmail.com
Thu Aug 21 21:01:13 EDT 2008
Hi David,
a belated thank you for this tip - I didn't think of trying to do it
in the select statement. For the record here is the syntax I used:
SELECT DATE_FORMAT(My_DATE_FieldName,'%W %M %D, %Y') ... etc.
produces a nice date like:
Monday September 20th, 2004
thanks again,
Sacha
On Wed, Jul 30, 2008 at 1:13 PM, Fawcett, David
<David.Fawcett at state.mn.us> wrote:
> Have you tried using a date format function in your SQL statement?
> http://dev.mysql.com/doc/refman/5.0/en/date-and-time-functions.html#func
> tion_date-format
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sacha
> Black
> Sent: Wednesday, July 30, 2008 3:07 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] date format?
> I've got point data in a MySQL database that I am displaying in my map.
> I'd like to label the points with a date, but the date format stored in
> the database looks like this:
> "2008-06-17 00:00:00"
> and we would like to put a label on the map in some kind of more user
> friendly format (and omitting the time portion which we do not need)....
> is this kind of re-formatting for labels possible in Mapserver? Prefer
> not to create a new field in the DB as there are thousands of records...
> any ideas?
> sacha
> Fri May 9 09:53:29 EDT 2008
> Hi list,
> using a shapefile with a Date column, is it possible to change the date
> format (string) that Mapserver will use in the WFS GetFeature output?
> Now it outputs:
> <ms:Discovery_date>19690101</ms:Discovery_date>
> whereas we would want 1969-01-01
> Best regards,
> Bart
