[mapserver-users] show only some point on the map
Till Adams adams at terrestris.de
Thu Aug 28 03:35:59 EDT 2008
Dear Valerio,
I guess what you need is this:
http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub
So add a variable substitution and insert it into your expression in the
CALL section of your layer.
Regards, Till
> Dear list,
> I have this question:
> I have a map file in which there is a POINT layer that uses a
> shapefile as datasource. Is possible with mapserver to do a request to
> show only some point on the map ?
> I know that i can show a group of points or only one point using
> FILTER and CLASSITEM into the map file but my goal is a bit different.
> In my case each poi has an ID into the shapefile, and I want make a
> request to serve  the follow question:
> Show on map the poi with ID 3,6,8.
> any suggetsion ?
> P.S I'm using CGI interface maybe is this possible to do with mapscript ?
> thanks everybady
> Valerio
> __________________________________________________
> Do You Yahoo!?
> Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da
> tanto spazio gratuito per i tuoi file e i messaggi
> http://mail.yahoo.it
> mapserver-users at lists.osgeo.org
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
