[mapserver-users] Parameters in memory
Jacolin Yves
yjacolin at free.fr
Fri Aug 29 05:00:52 EDT 2008
Le Friday 29 August 2008 10:49:01 Till Adams, vous avez écrit :
> Jacolin Yves schrieb:
> > Hi list,
> > I have a strange issue using mapserv. I think this will be difficult to
> > reproduced, but I try asking in the list ;)
> > I am using mapserver as WMS service with Openlayers and tilecache. We are
> > moving our application to the release 2 and so we are cleaning the
> > spatial configuration. For example, we changed the SHAPEPATH parameter
> > from /var/local/cartoweb/transparens_immo/cres to /var/local/spatial/.
> > This is a very good example because my problem come from this changing.
> > So we moved spatial data in this new directory and changed SHAPEPATH in
> > the mapfile. This change works for almost all layers. I don't know why,
> > some layers don't want to use the new SHAPEPATH and I get this kind of
> > error when requesting WMS layer (here named ortho_92):
> > <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> > <!DOCTYPE ServiceExceptionReport
> > SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> > <ServiceExceptionReport version="1.1.1">
> > <ServiceException>
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'ortho_92'.
> > msDrawRaster(): Unable to access file.
> > (/var/local/cartoweb/transparens_immo/cres/Referentiel/Bd_Ortho/92/92-200
> >3-0595-2415-LA2E-C07.ecw) </ServiceException>
> > </ServiceExceptionReport>
> > Is this something known? I am using mapserver 4.10.1 on Debian Etch.
> > Mapserver come from C2C repository. thanks for your help.
> > Regards,
> > Y.
> Yves,
> sounds like you are using tileindexes? Within these the path in
> attribute "location" maybe wrong
> because unchanged?
> Till
:O
Good point !
Big thanks Till !!!
Y.
Yves Jacolin
http://softlibre.gloobe.org
