[mapserver-users] Fractional line widths?
thomas bonfort
thomas.bonfort at gmail.com
Sat Aug 30 03:22:30 EDT 2008
Sorry for not hopping into the thread earlier, blame holidays :)
For the time being, you can achieve similar output with mapserver 5.2,
by using the OPACITY keyword at the style level
STYLE
COLOR r g b
OPACITY 50 # essentially the same as WIDTH 0.5
WIDTH 1
END
cheers,
thomas
On Tue, Aug 19, 2008 at 4:28 PM, Dane Springmeyer <blake at hailmail.net> wrote:
> Fantastic, thanks for the feedback everyone.
> Dane
> On Aug 19, 2008, at 5:39 AM, Steve Lime wrote:
>> We've talked about this as part of a package of graphics-related
>> enhancements. Look for
>> it in 5.4 soon.
>> Steve
>>>>> "Tamas Szekeres" <szekerest at gmail.com> 08/18/08 7:06 PM >>>
>> Dane,
>> I think it would be implemented by means of replacing the int-s with
>> doubles at the style and the symbol definitions and the corresponding
>> interfaces since AGG have already been using doubles internally in the
>> code.
>> Best regards,
>> Tamas
>> 2008/8/19 Dane Springmeyer <blake at hailmail.net>:
>>> Tamas,
>>> Great, thanks!. I'll file a ticket then regarding the agg render and
>>> adding
>>> a FORMATOPTION for generating 'thinner' looking lines.
>>> My question comes from the context of comparing Mapnik's agg output to
>>> mapserver. Mapnik seems to interpret user-entered fractional widths in a
>>> clever way, by lightening the color and intensity.
>>> I'm comparing this graphic generated with a width=0.1 with Mapnik:
>>> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/xml_config/map/hello_world_using_xml_config.png
>>> to this graphic generated with Mapserver with Width 1.0:
>>> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/mapserver_comparison/mapfile_config/map/hello_world_with_mapserver_mapfile.png
>>> It fully possible that my mapfile is not doing an equal comparison, so if
>>> anyone has suggestions I've pasted it below.
>>> Thanks,
>>> Dane
>>> # This mapfile mirrors the mapnik hello world example
>>> here:
>>> http://mapnik-utils.googlecode.com/svn/trunk/tutorials/hello_world/pure_python/
>>> # A map can be generated from it by running shp2img.
>>> # For example:
>>> # $ shp2img -m world.map -o map/hello_world_with_mapserver_mapfile.png
>>> # or
>>> # once you have installed the mapserv cgi use this url:
>>> http://localhost/cgi-bin/mapserv?map=/path/to/this/mapfile/world.map&layers=world&mode=map
>>> MAP
>>> IMAGETYPE AGG
>>> EXTENT -180 -93 180 86
>>> SIZE 600 300
>>> SHAPEPATH "../../data/"
>>> IMAGECOLOR 70 130 180
>>> OUTPUTFORMAT
>>> NAME 'AGG'
>>> DRIVER AGG/PNG
>>> IMAGEMODE RGB
>>> MIMETYPE "image/png"
>>> END
>>> LAYER
>>> NAME world
>>> DATA world_borders.shp
>>> STATUS ON
>>> TYPE POLYGON
>>> CLASS
>>> NAME "World"
>>> STYLE
>>> COLOR 242 239 249
>>> OUTLINECOLOR 127 127 127
>>> WIDTH 1
>>> END
>>> END
>>> END
>>> END
>>> On Aug 18, 2008, at 3:53 PM, Tamas Szekeres wrote:
>>> Dane,
>>> I think it's reasonable but would only be feasible for the AGG renderer
>>> though.
>>> Best regards,
>>> Tamas
>>> I can see from http://mapserver.gis.umn.edu/docs/reference/mapfile/style
>>> that only integers are supported for the Style > Width parameter.
>>> Are thinner lines (a float type) a possibility or have they been
>>> considered
>>> in the MapServer code base?
>>> I can't find anything in trac to suggest so, but I thought to check here
>>> before filing a ticket.
>>> Thanks,
>>> Dane
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
