mapserver 4.10.2 and debug informations
patrice canonici
patrice.canonici at GMAIL.COM
Mon Feb 4 09:44:17 EST 2008
Hi
I'm trying to have lots of debug information into log file.
In the mapfile there is :
MAP bloc : DEBUG ON
WEB bloc : LOG "/tmp/mapserver.log"
in many LAYER bloc DEBUG ON
mapserver is configure as follow :
./mapserv -vMapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
mapserver is running into apache httpd 2.0.59 (compiled, not from rpm)
on Red Hat Linux.
/tmp/mapserver.log remains empty, and I get only "error" (that seems
not to be errors) level message into the httpd error_log file.
is it possible to have these informations into the mapserver log file
? (/tmp/mapserver.log). ? if yes, how ?
and, is it possible to have a more verbose log ? with debug/warn/...
informations ?
Regards
Patrice
