qstring validation
Hunter, David - St. Louis Park, MN David.Hunter at FNIS.COM
Wed Feb 6 18:35:11 EST 2008
Since moving to mapserver 5.0 (mostly to test AGG), a layer in my map
file that has this class definition:
            EXPRESSION (%qstring%)
            COLOR 230 230 179
The query no longer works.  If I change it to an explicit query string,
The polygon is filled as expected.  In the "MapServer 4.10 to 5.0
Migration Guide", there is mention that in the case of qstring queries,
the qstring_validation_pattern layer-level metadata is required.  It
also says the absence of this setting produces a fatal error.  My maps
still work, they just do not fill in the polygon that matches the
I cannot find any examples or documentation for the
qstring_validation_pattern setting.  Can anybody give me a pointer in
the right direction?
David S. Hunter
Lead Software Engineer
Fidelity National Geographic Solutions
division of Fidelity National Information Services
5353 Gamble Drive, Suite 201
St. Louis Park, MN 55416
Email: david.hunter at fnis.com <mailto:david.hunter at fnf.com>
Phone: 952.542.1440 ext. 256
Fax: 952.542.3859
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080206/136f1176/attachment.html
