[mapserver-users] Netcdf / WCS
vincent
vincent.thierion at ema.fr
Tue Feb 19 10:38:49 EST 2008
Hello,
I would like to create Web Coverage Service from one netCDF file in
following http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
My netCDF store rainfall matrix every five minutes in the "pluie"
variable. This the CDL :
dimensions:
time = UNLIMITED; // (496 currently) // (has coord.var)
x = 50; // (has coord.var)
y = 50; // (has coord.var)
variables:
int Lambert_Conformal;
:grid_mapping_name = "lambert_conformal_conic";
:standard_parallel = 43.20317, 44.99683; // double
:longitude_of_central_meridian = 2.337229; // double
:latitude_of_projection_origin = 44.1; // double
:false_easting = 600.0; // double
:false_northing = 3200.0; // double
:_CoordinateTransformType = "Projection";
:_CoordinateSystems = "ProjectionCoordinateSystem";
:_CoordinateAxes = "y x";
:_CoordinateAxisTypes = "GeoX GeoY";
double pluie(time=496, y=50, x=50);
:units = "mm/h";
:long_name = "Intensité de pluie";
:coordinates = "lat lon";
:grid_mapping = "Lambert_Conformal";
:_CoordinateSystems = "ProjectionCoordinateSystem LatLonCoordinateSystem";
char LatLonCoordinateSystem;
:_CoordinateAxes = "time lat lon";
char ProjectionCoordinateSystem;
:_CoordinateAxes = "time y x";
:_CoordinateTransforms = "LambertConformalProjection";
double time(time=496);
:long_name = "rainfall time";
:standard_name = "time";
:units = "seconds since 1970-01-01 01:00:00";
:axis = "T";
:_CoordinateAxisType = "Time";
:bounds = "time_bnds";
double x(x=50);
:units = "km";
:long_name = "x coordinate of projection";
:standard_name = "projection_x_coordinate";
:_CoordinateAxisType = "GeoX";
double y(y=50);
:units = "km";
:long_name = "y coordinate of projection";
:standard_name = "projection_y_coordinate";
:_CoordinateAxisType = "GeoY";
double lat(x=50, y=50);
:units = "degrees_north";
:long_name = "latitude coordinate";
:standard_name = "latitude";
:_CoordinateAxisType = "Lat";
double lon(x=50, y=50);
:units = "degrees_east";
:long_name = "longitude";
:standard_name = "longitude coordinate";
:_CoordinateAxisType = "Lon";
:Zone_Radar = "Gard-Ceze Amont";
:history = "Tuesday 19 February 2008, 00:00";
:Projection_cartographique = "Lambert III";
:X0 = 700.7; // double
:Y0 = 3189.1; // double
:Conventions = "CF-1.0";
The HowTo of Mapserver Website seems adapt to a set of netcdf files but
not for one netCDF file including several bands corresponding to each
time step.
When I use :
gdal_translate -ot Float64 -of gTiff -b 300 -sds
netCDF:"pluie-4-20020908.nc":pluie test.tif
A tif file is created based on the 300th band of "pluie" variable
When I use :
gdaltindex test.shp NETCDF:pluie-3-20020908.nc:pluie
A shape file is created but without every band, only a record with the
netcdf extent and his name
I suppose i have to create a new record for each time's band of netcdf
file in the tileindex after creating with gdaltindex ?!
I would like to use the Python Script of Norman Barker
http://www.nabble.com/Map-File-Problem--td5541099.html#a5544967
But it is possible or the only solution is to create a tif file for each
band ?
Thanks
Vincent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080219/192e5db1/attachment.html
