[mapserver-users] AGG_Q + raster problem
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 19 12:07:10 EST 2008
Hans,
Try removing PROCESSING "DITHER=YES" from the ORTOFOTO
layer definition. I think it is converting the 24-bit input
raster to 8-bit before it renders it to the 24-bit output
image.
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: "'Brent Fraser'" <bfraser at geoanalytic.com>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, February 19, 2008 9:36 AM
Subject: RE: [mapserver-users] AGG_Q + raster problem
Hi, Brent
I'm using mapserver 5.0.0 for Windows.
I have no problems with vectorial data (shapefiles). The
rest of my mapfile
is like this:
MAP
NAME 'gmap'
SIZE 800 600
STATUS ON
EXTENT 559273 4709373 584263 4737543
FONTSET cartografia.fonts
TRANSPARENT TRUE
IMAGECOLOR 239 235 231
SHAPEPATH "C:\ms4w\apps\ka-map-1.0\mapdata\xxxxx\"
IMAGETYPE AGGA
CONFIG "PROJ_LIB" "C:\ms4w\proj\nad\"
WEB
IMAGEPATH 'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\tmp\'
IMAGEURL 'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\tmp\'
END
PROJECTION
"init=epsg:23029"
END
REFERENCE
SIZE 193 236
'C:\ms4w\apps\ka-map-1.0\htdocs\xxxxx\css\img\keymap.gif'
END
LEGEND
STATUS ON
KEYSPACING 5 10
KEYSIZE 20 12
IMAGECOLOR 255 255 255
LABEL
TYPE TRUETYPE
FONT bluehigh
COLOR 0 0 0
OUTLINECOLOR 254 254 254
SIZE 12
END
END
OUTPUTFORMAT
NAME 'AGGA'
DRIVER AGG/PNG
IMAGEMODE RGBA
FORMATOPTION "TRANSPARENT=ON"
#TRANSPARENT ON
END
#SYMBOL DEFINITION
WEB
HEADER "tlg_header.xml"
FOOTER "tlg_footer.xml"
END
#MDT
LAYER
NAME "MDT"
STATUS DEFAULT
GROUP "MDT"
TYPE raster
OPACITY 75
#PROCESSING "SCALE=AUTO"
CLASS
MINSCALE 15000
END
DATA "mdtxxxxx2.tif"
END
#ORTOFOTO
LAYER
NAME "ORTOFOTO"
STATUS DEFAULT
GROUP "ORTOFOTO"
TYPE raster
DATA "ortoxxxxx.ecw"
CLASS
MAXSCALE 15000
END
END
#LAYERS DEFINITION
END ## end Map
-----Mensaje original-----
De: Brent Fraser [mailto:bfraser at geoanalytic.com]
Enviado el: martes, 19 de febrero de 2008 16:46
Para: Hans Castorp
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] AGG_Q + raster problem
Hans,
That is stange. I've tested mapserver 5.0.0. Beta 4 (it's
the only v5 I've got compiled) and it gives me a 24 bit
color image. What version of Mapserver are you using? Can
you send your entire map file?
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
To: <bfraser at geoanalytic.com>
Sent: Tuesday, February 19, 2008 2:21 AM
Yes, I'm still getting a quantized image using this
statement:
OUTPUTFORMAT
NAME 'AGG_PNG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
Enviado el: lunes, 18 de febrero de 2008 21:37
Para: Hans Castorp
Asunto: RE: [mapserver-users] AGG_Q + raster problem
So when you remove all the quantize options, you still get a
quantized
image on output? Using something like:
OUTPUTFORMAT
NAME 'AGG_PNG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
> This, by example
> De: Guillaume Sueur
[mailto:guillaume.sueur at neogeo-online.net]
> Enviado el: lunes, 18 de febrero de 2008 19:04
> Para: Hans Castorp; mapserver-users at lists.osgeo.org
> what's the result in standard AGG mode ?
> Hans Castorp a écrit :
>> The result is the same with or without this line...
>> De: Guillaume Sueur
>> Enviado el: lunes, 18 de febrero de 2008 18:59
>> Para: Hans Castorp
>> quantize_colors=255 is maybe the reason why your colors
are reindexed on
>> a 256 colors palette.
>>> Thanks Brent, but there is a mistake, the example I
attached is not the
>>> mapservers original output: I have prepared it and give
..gif extensión.
>>> This is the way I configure my output:
>>> OUTPUTFORMAT
>>> NAME 'AGG_Q'
>>> DRIVER AGG/PNG
>>> IMAGEMODE RGBA
>>> FORMATOPTION "QUANTIZE_FORCE=ON"
>>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>>> FORMATOPTION "QUANTIZE_COLORS=255"
>>> END
>>> Thanks in advance.
>>> Enviado el: lunes, 18 de febrero de 2008 18:17
>>> Para: Hans Castorp
>>> Hans,
>>> GIF supports only 256 colors. Use PNG (or JPG) for an
output format.
>>> Brent Fraser
>>>> Hi to all,
>>>> I'm trying to publish a cartography using both
vectorial and raster
>>>> layers.
>>>> I'm using mapserver 5 and agg_q as output format. There
is no problem
>>>> about
>>>> vectorial files (shapefiles): all work fine.
>>>> The only problem I'm having is trying to publish some
raster stuff: an
>>>> aerial photo (.geotiff) and a digital terrain model
(.ecw). I'm not
>>>> capable
>>>> to make the output showing real colours; there is an
example attached
>>>> to
>>>> this mail (an aerial photo).
>>>> My mapfile looks in this way:
>>>> LAYER
>>>> NAME "MDT"
>>>> STATUS DEFAULT
>>>> GROUP "MDT"
>>>> TYPE raster
>>>> DATA "mdt.tif"
>>>> CLASS
>>>> MINSCALE 15000
>>>> END
>>>> END
>>>> LAYER
>>>> NAME "ORTOFOTO"
>>>> STATUS DEFAULT
>>>> GROUP "ORTOFOTO"
>>>> TYPE raster
>>>> DATA "ortofoto.ecw"
>>>> CLASS
>>>> MAXSCALE 15000
>>>> END
>>>> END
>>>> What I have to do to solve this?
>>>> Thanks in advance to everyone.
>>>> Hans Castorp
>>> No virus found in this incoming message.
>>> Checked by AVG Free Edition.
>>> Version: 7.5.516 / Virus Database: 269.20.7/1285 -
Release Date:
>> 18/02/2008
>>> 5:50
>>> No virus found in this outgoing message.
Release Date:
>> 18/02/2008
>>> 5:50
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Guillaume SUEUR
> Expert SIG et OpenSource
> NEOGEO
> 46 RUE MATABIAU
> 31000 TOULOUSE
> 06 74 91 95 20
> Site web : http://www.neogeo-online.net
> Version: 7.5.516 / Virus Database: 269.20.7/1285 - Release
Date:
> 18/02/2008
> 5:50
Date:
> 18/02/2008
> 5:50
Version: 7.5.516 / Virus Database: 269.20.7/1286 - Release
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
Date: 18/02/2008
18:49
